How to replace my thermal compound?
I’ve been searching for a way to access the CPU and GPU to replace the thermal compound on my laptop, but I haven’t seen anything that shows how, even on here. Does anyone know how to do this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @kokohaishere ,
Here’s a link to the service manual for your laptop, taken from this webpage
Scroll to p.49 to view the necessary pre-requisite steps and then the procedure to remove / replace the heat sink assembly.
Once that is removed you can clean off and renew the thermal paste on the CPU/GPU etc.
You can also clean the fan at the same time ;-)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 31
今までの合計 2,123
