メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
274回答 すべてを表示
cold replacement of the battery
My early 2013 MacBook pro 15” needs a battery replacement. The batteries are swollen. To make removing the battery pack safer, can this be done in cold conditions. I noticed that leaving the MBP outside for a day. The swelling decreased significantly. Will the adhesive remover work in temperature close to freezing?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I haven't tried to remove the battery yet. But one question. Would the dental floss method of cutting through the dissolved adhesive be safer?
さんによる
コメントを追加
2件の回答
ベストアンサー
Yep, it may take noticeably longer but will still work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Good question! While the swelling will decrease as the battery gets colder, the effectiveness of the solvent will decrease as well.
So the trick is keeping the battery cold but allowing the aluminum uppercase to stay at room temp. Using a waterless Ice block you use to keep food cold should offer the cold to keep the battery under control as you allow the case to warm up.
The cold will also prevent the solvent to evaporate as quickly so you want to use less.
I would get a few sets of plastic cards to wedge underneath the battery cells as you free them up. You may need to re-cool your system and attack it again a few times. MacBook Pro 15" Retina Display Early 2013のバッテリーの交換
MacBook Pro 15" Retina (Mid 2012-Early 2013) Batteryの画像
製品
$79.99
Plastic Cardsの画像
製品
Plastic Cards
$2.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Pohlman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 137
