メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年9月発売。モデル番号はT100T。クアッドコアIntel® Atom™プロセッサと2GBのRAMを搭載した2-in-1ポータブルデバイス。
Not powering on after charge
My T100TA has been habing trouble turning on. I popped the lid, unplugged the battery and left it unplugged for a good 45 seconds to a minute. Put it back together and I plugged it in overnight and now its white (leads me to believe the battery is ok). The white power LED still flashes 5 times even though,from what ive read, Ive performed a hardware reset. I will detail what Ive tried.
# Holding the power button down until white led flashes 5 times (camera side led turns on, no other response from device than that)
  1. Holding power button for 10 seconds (similar to 1. but after the 10 second mark the camera led turns off)
  2. Holding down “Windows Button" and power button simultaneously for 15 and 30 seconds (same result as 2. Tried holding them as if normal power on[2 or 3 seconds])
  3. Holding the volume up/down button and power button simultaneously (Same result as 1. Tried it for 15-30 seconds but results in the same reaction as 2.)
  4. Holding power button for over a minute (Same result as 2.)
Also tried all the methods listed above with the power connector plugged in. I also tried them with the battery unplugged before I charged it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Bad power adapter, battery or screen could be the reasons why the device will not turn on.
Check out how to resolve these situations: Asus Transformer T100 Troubleshooting
In case any further problem, you’d better back up your computer regularly.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I've checked the specifications of the micro usb cable compatibility (its not a 'charge only' cable) and the power adapters rating (5v 2amp) so that should be good.
Im not sure how else to test if the battery is ok other than seeing if a orange/red led is present after charging it overnight.
It could be the screen but I highly doubt it since its been stored safely and there have been no real issues with it prior.
さんによる
You may just troubleshoot carefully by yourself, or ask some experts to do tests. Wish you good luck!
さんによる
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 643
