メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.4GHzまたは1.6GHzプロセッサ / 64GBまたは128GB SSD
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
画像
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
画像
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
11 件のコメント
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see iFixitでの質問に画像を追加する方法
さんによる
try a different dc in board
さんによる
What’s that involve, is it doable myself?
さんによる
the i/o board guide that trevor posted
さんによる
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
さんによる
6件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Two possibilities:
Most likely possibility: bad battery
MacBook Air 11インチ Late 2010 バッテリーの交換
MacBook Air 11" (Late 2010) Battery
Less likely possibility: I/O board
MacBook Air 11" Late 2010 I/Oボード交換
MacBook Air 11" (Late 2010) I/O Board
Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports.の画像
製品
$29.99
Replace the 4790 mAh battery compatible with MacBook Air 11" (2010). 35 Watt Hours (Wh), 7.3 Volts (V).の画像
製品
$49.99
MacBook Air 11" Late 2010 バッテリーの画像
ガイド
難易度:
中レベル
15 minutes
MacBook Air 11" Late 2010 I/Oボードの画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
andy hawkins さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 14
今までの合計 482
