kodak c813 lcd replacement
I am replacing my lcd screen on my kodak c813 how do I connect the new screen to the camera. I dont know how to connect the new yellow tab to the camera
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Kodak Easyshare C813のLCD交換 take a look at step 16.. it shows a connector that has two parts, you need to lift the tab on the side where the flex enters (it's like a hinged door, you are literally opening the door not removing it) once the hinge is opened you should just be able to slide the flex out.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 6
過去 30 日: 23
今までの合計 1,359
