メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日にAppleから発売されたiPhone 6sの修理情報およびガイド。モデル:A1688、A1633
Unable to activate - error.
Trying to set up this iPhone 6s and I keep on getting this message.
Unable to Activate
An update is required to activate your iPhone.
I have put it into restore mode twice now into iTunes on my Mac and attempted to Update & Restore. Still coming back with the same thing. Haven’t tried just restoring but it’s saying it needs an update. Also has the small exclamation mark in the top left hand corner with a “No Service” sign next to it, even though it has a SIM in it.
Any help would be much appreciated.
— Sam :)
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 37
13 件のコメント
Iphone 6
Unable to activate
Solution
さんによる 共有
I have no clue how on earth is this website gained enough SEO To be this high up in this search there’s absolutely zero knowledge or advice on this page is absolutely useless
さんによる 共有
If you have a question, ask. If you have a better answer you're free to contribute, anytime. Criticism is always welcome, pointless whining is useless.
さんによる 共有
hi
i dont active my phone
after update whit itunse back again to unable to activate your phone page
さんによる 共有
i can't activate iphone 6s after update.unable to activate an update is recuired to active.please help me
さんによる 共有
8件以上のコメントを表示
コメントを追加
11件の回答
最も参考になった回答
I think your phone not have IMEI now.... Check on Activision screen symbol “I “ ….. When you not see the IMEI is baseband problém... Without IMEI not possible
このアンサーは役に立ちましたか?
スコア 12
5 件のコメント:
@vojtech So, without the IMEI it's impossible to restore?
さんによる 共有
what do you mean that there is ni imei how is it possible
さんによる 共有
how imei not show in the iphone is it some things are missed or stolen
board
さんによる 共有
A fault in baseband circuitry is enough to have a phone being unable to provide the associated IMEI code. Nothing to do with a stolen board.
さんによる 共有
how solution???
さんによる 共有
コメントを追加
Follow these steps:
  1. Check the list on the System Status page. If the box by iOS Device Activation isn't green, try to activate your iPhone later.
  2. If asked to enter your password as you activate your iPhone, enter the password. (A password prompt means that Activation Lock might be enabled in Find My iPhone.)
  3. Restart your iPhone (Skip since you have tried this method).
  4. If you're using a cellular data connection, connect to a reliable Wi-Fi network instead.
If you still can't activate, here's how to activate your iPhone through iTunes instead:
  1. Make sure that you have the latest version of iTunes.
  2. Check that your computer has an Internet connection.
  3. Open iTunes on your computer. With the cable that came with your iPhone, connect your iPhone to your computer.
  4. Wait while iTunes detects and activates your iPhone:
  5. If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone.
  6. If an error in iTunes says that the SIM card isn't compatible, contact your carrier.
If all of the methods not working, try to contact Apple Support.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
iUnable to activate related to baseband issues.If the phone fails to detect IMEI while on activating the phones.There is common problem shows on.The way of repair that problem
.1- BBPMU reball
2- Wtr problem
3- BBCPU reball
That need to hardware skill that can`t be fixed with software.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Sim not valid iphone6s
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Here's a bypass to get more usability out of your device (not a complete fix)
https://youtu.be/3NSWsWeINC8
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My iPhone not activated no service
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My iPhone no service problem not activated
さんによる 共有
コメントを追加
Why showing unable to activate
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My iphone like this this for 1 week now i cant call nothing. and now i cant live.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my iphone 6s unable to activate
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my problem is that my iPhone is saying unable to activate ,You iPhone could not activated because the activation server cannot be reached
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You have to jailbreak it with ramdisk and create new apple id
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sam Mileberg さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 51
今までの合計 35,420
