If you don’t want any problems when you use dedicated graphics card (AMD), you MUST use only the default display settings for your retina display (i.e. 1440x900, it may also be designated as 2880x1800 in your computer since it’s quadrupled by using factor 2x2 for each figure, due to “retina” specification).
You can use “more space” or “larger text” options in Mac’s own display settings only when you switch off the dedicated graphics card.
Hope this helps.
I can add one more additional thing to resolve the problem: You can disable switching (between dedicated graphic to integrated graphic) in the energy saver preferences, and this issue may be totally gone. The battery life may get shorter of course, since you are no longer saving energy (using dedicated graphics all the time).
By the way how do you know (how do you make sure) that it uses integrated graphic all the time ? I mean did you find a way to switch off the dedicated graphics card (such as https://gfx.io) ? I’m asking this because you say there is no problem when it uses only integrated graphics, however this is not normally possible by original native apple software. Either you have dedicated graphics all the time if you disable energy saving feature, or you have intermittent switching between dedicated graphic and integrated graphic during use. My guess is, the time periods you don’t have any problem are when you are on dedicated graphics all the time.
5 件のコメント
Lets correct a few points here your system came in two versions:
- MacBook Pro 15" Mid-2015 (Intergraded Graphics)
- MacBook Pro 15" Mid-2015 (Dual Graphics)
Basically the Dual Graphics models have in addition to the Intel Iris Pro 5200 intergraded graphics within the CPU chip have the Radeon R9 M370X GPU chip (not a card)
DanJ さんによる 共有
Hello, it is the MacBookPro11,5(Dedicated Graphics)
Satashi Zero さんによる 共有
No worries, I knew that. Just wanted to make sure we where on the same page on what the differences are.
DanJ さんによる 共有
Hello did you ever find a fix to this problem? I have the exact same issues with my mid-2015 as well. I tried all of the fixes and still nothing. Fans will get noisy, mac will overheat and screen will go white.
Michael Fenderson さんによる 共有
no, maybe problem with logic board (or GPU), I tried replacing heat sink, but the issue still persists. replace logic board is too expensive, so I have to live with this issue (and use gfxCardStatus)
