メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Googleの第2世代Pixel XLは、角が丸みを帯びた6インチのP-OLEDディスプレイを搭載しています。ストレージ容量は64GBと128GBの2種類で、カラーはJust Black(ジャストブラック)とBlack & White(ブラック&ホワイト)の2色展開です。2017年10月19日発売。
Is my screen fixable?
Hello,
I recently smashed my phone on concrete when I slipped while running. The top left corner of my Pixel took the most damage.
画像
画像
Is my phone repairable? I’m assuming I’ll need to get a front camera replacement and a full screen + digitizer. I can’t tell if the frame is damaged beyond repair… Any advice/comments would be appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
if price is a concern and the phone still functions..looks like it's just the glass over the camera and may not involve the actual camera at all/touchscreen functions intact, you could just apply sticky tape/contact adhesive to prevent further damage etc and keep on using the phone. you may have a few pieces of glass over the camera which may show up on photos, but seeing as this is the selfie camera, if you don't use it what does it matter?
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Hi,
This link may be of some help.
They should give you a quote for the repair if nothing else.
Update (11/06/2018)
Here’s a link to the ifixit Google Pixel 2 XLのスクリーンの交換 guide.
Once you have removed the old screen you should be able to determine what else, if anything, needs to be replaced. It may depend on how well the new screen sits back in.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I appreciate the link, but it doesn't answer my question. I'm trying to decide whether or not ifixit tools will suffice in repairing my Pixel device.
さんによる 共有
The answer is yes. You should change the screen completely. Your screen has part of the LCD broken, so it is not possible to repair. You can change the glass, but the spot on the LCD has no repair.
The camera should try it to know if it should change or not, if it looks good I would change it. Due to the opening problem, you must first remove the screen to access the rest of the terminal, I advise you to be sure before sticking the screen to the chassis.
If the frame is damaged, it can be repaired with a sandpaper and patience. But it will not be like new.
さんによる 共有
You will need additional stickers that may not come with the screen. Luck!
さんによる 共有
コメントを追加
回答を追加する
Timothy Lee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 23
今までの合計 2,014
