メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
eMacは教育市場向けに設計されたオールインワンのG4搭載Macで、2002年4月に発売されました。これはCRTディスプレイを使用した最後のMacであり、学校やその他の教育機関向けに低価格で販売されました。
Is my eMac missing a jumper?
I just bought an eMac from a local thrift shop. On the box it said it used European power and came with an Apple European two pronged chord but on the machine itself it says 120V near the serial number and on the bottom access door. When I plug it in to my American outlet and turn it on, nothing happens so I am guessing it is true that it was somehow set to use 220V.
I have been referring to a service manual online, but my computer is a different variation (it is the 1.25 GHz USB 2.0 model). Mine does look the same as the one in the ifixit guide though. I am pretty sure I need a jumper somewhere, but there is only one photo on the ifixit guide of the spot I need to look at, but the spot I need is obscured. Can anyone take a photo of the board (not the logic board, but the huge circuit board under the CRT) where the power cable connects? I’m referring to the spot in the guide where the blue and brown wires from the power socket connect to the board with a white plug. If you’re looking at the eMac from the top front, its to the left of the CRT neck.
Here is what mine looks like:
画像
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
@nabru50 give us all the numbers from the back of your eMac so we can determine exactly what model you have.
さんによる
Model No: A1002
G4-1.25GHz/256/40/Combo/56K/110V
100-120VAC,3.5A,50-60HZ
さんによる
コメントを追加
1 件の回答
ベストアンサー
@nabru50
it will work much better if you post some pictures of what you are looking for. that way we do not need to guess. this is the information I got:
Table 1: Jumper Settings
Voltage / Voltage Jumper /LHR Jumper
110 V /Jumper is on /Jumper is on
220 V /Jumper is off /jumper is on
220 V /Jumper is off /Jumper is off, LHR module installed
with LHR module
画像
画像
このアンサーは役に立ちましたか?
スコア 3
12 件のコメント:
This does look like mine. I am missing the voltage jumper with 2 pins. Any idea where I could get one?
さんによる
@nabru50 P902? I would just temporarily try with a cable with alligator clips. See what happens
さんによる
That did it. It still wouldn't work at first, but I pressed the power button multiple times and it eventually kicks on after 2-3 presses. Thanks!
さんによる
May I please use this thread to ask a question about a US eMac (110V 60Hz) which I want to use in Singapore (220V 50Hz)? If I remove the above-mentioned Voltage jumper, should I be able to plug in directly to 220V?
さんによる
US 110V eMacs do not have LHR installed by default. So, hopefully, I do need to remove the LHR jumper.
さんによる
7件以上のコメントを表示
コメントを追加
回答を追加する
Phillip Urban さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 15
今までの合計 584
