メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Phone crashed while testing new screen (no screws installed) iTunes ok
I was replacing a screen assembly on iphone 6. before putting the screws back in I turned the device on and tested it. it was working fine. The digitizer shifted a tiny bit (maybe it pulled a connector off?) but the phone went off entirely. I have not been able to get it back on since. I did try a second brand new replacement screen assembly (known good) and it does the same thing.
I can power on the phone and iTunes DOES see and communicate with it.
I installed the screen again (no home button or any connectors except the screen and digitizer) - powered on, used a flashlight and could NOT see anything on the screen in the dark.
All pins on connectors look good. I dont thinks the backlight filter since I cant see anything with a flashlight.
Any ideas or suggestions. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I should mention, I did not put any screws in so it did not short anything out that way.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
First thing would be to take a close look at the connectors and surrounding areas for any physical damage. If you cannot see anything at all even with a clean screen and a flashlight, you may be looking at a display IC. If just the backlight goes out you can still see a faint image, but if just the display driver (u1501) or display boost (u5302_RF) goes out you can usually still see a backlight on with the screen outside of the frame. Hope this helps, but always start with the easy stuff, like looking over the board for physical marks.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kyle B さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 45
