メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年9月22日発売。モデル番号はA1864、A1897。GSMモデルとCDMAモデルがあり、ストレージは64GBまたは256GBのオプションが用意されました。本体カラーはゴールド、シルバー、スペースグレイの3色展開です。
Earpiece Not Working After Screen Replacement
This is probably the THIRD iPhone 8 or 8+ that has had this issue. Even though we were careful to remove the camera flex cable and the tape with it, and transfer it to the new LCD/Digitizer assembly, the earpiece REFUSES to work. The camera works just fine. I need assistance and answers. I have cleaned the contacts with alcohol. I have installed Kapton tape. I have switched out the piece with a new flex cable and new ear piece speaker. Yet, I know it worked BEFORE we took the phone apart. Suggestions on how to use the ORIGINAL flex cable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
1 件の回答
You want to make sure that the metal bracket that covers the earpiece and speaker is properly aligned, and none of the tiny springs on the receiver are bent or improperly seated. They should all evenly be pressed when the bracket is screwed into position.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank you for the suggestion. I had to get this back together for the customer, but a weird thing happened. I test it without the bracket for the flex cable installed on the logic board. In a last ditch effort, I cleaned the connector to the logic board and installed the bracket. Then it worked!
さんによる
Good work, glad you figured it out, cleaning the connector was smart too, pesky iPhones haha.
さんによる
I will try everything,,earpiece not worked then I changed the screen back to originaland violaearpice now working,, solution is : use only original LCD
さんによる
コメントを追加
回答を追加する
Scott Thompson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 48
今までの合計 7,633
