メインコンテンツにスキップ
Repair guides and support for your LG TV.
1342回答 すべてを表示
LG TV - powers on, but black screen after LG logo, backlight is on
Hi guys,
A few days ago my TV screen suddenly went black and I don't quite know what to do.
Basically, if I turn it on the LG logo will appear for about a second or so and then the screen goes black. although backlight stays on. The only button on the remote that does anything is the on/off one.
Called up 2 tv repair shops and both told me almost straight away that it sounds like the panel is dead and I need to basically replace the whole screen (a $3,000 repair), which I don't quite believe.
When I took the TV off the wall and tried turning it on again a few days later - it worked fine for maybe 10 seconds and then the screen went black again.
Maybe there is a loose connection somewhere or something.
Any ideas? I hope there's something I could try before I throw it away.
The model is LG 70" UH635T, I could find it in the list so had to choose a random LG model when posting this question
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 13
39 件のコメント
My LG 55 TV turn on, show the LG symbol for 2-3 seconds then goes to black screen/shut downs. Anyone know if this is the power supply or main board. I have sound through the surround sound but not TV.
さんによる
Stan what was the solution? did you manage to fix your TV? I am having the same problem
さんによる
Mine just went too!….The same %#*@ problem!!!
さんによる
Mine went out too. Haven't found a solutions
さんによる
Hi guys,
No, haven't fixed it as I couldn't source replacement parts for adequate price. The TV is just sitting in my garage at the moment.
さんによる
34件以上のコメントを表示
コメントを追加
10件の回答
ベストアンサー
@crashxxx backlight on without video is usually a main board problem you did not tell us if you get any sound. You need to check out all your video inputs and see if that changes anything. If it does not remove the back of the beast and take a look at all the boards for any obvious damage (leaking or domed looking caps etc.). Post pictures of your boards so we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that. The problem could be the panel but it could also be the power board or the main board.
このアンサーは役に立ちましたか?
スコア 5
19 件のコメント:
Hi There,
Took the back cover off and uploaded the images of all 3 boards.
Turned the TV on after a month or so and it worked again for about 10 min. and then the same issue. I noticed a few more things:
- There is a green LED LD701 on the power board that starts blinking when the screen goes black (blinks 5 times)
- The red standby light blinks 3 times when I I turn the TV on and before backlight turns on
I was thinking of trying replacing all 3 boards (starting with the power board) to see if it fixes anything. Sounds like a better option than buying a new tv... not sure if I should really start with the power board though.
Thanks for your help!
さんによる
@crashxxx does the sound remain when the image turns black? this sounds more like a main board issue than a power board issue.
さんによる
I was playing a movie via USB stick. As soon as the screen goes black - there is no sound. Basically the only thing that is on is the backlight. It is also weird that if I don't touch the TV for a week - it will turn on again and work fine for another 10min or so. I also realised that there was a thunderstorm when the TV died and on the same day my power board died (unfortunately, the tv was connected directly into the wall socket so there was no surge protection). Not sure if this info is useful. It feels like there is some sort of protection mechanism that kicks in and shuts the TV down.
さんによる
@crashxxx all of this "no sound. Basically the only thing that is on is the backlight." and" It is also weird that if I don't touch the TV for a week - it will turn on again and work fine for another 10min or so" sounds like a bad component on the main board. It comes on for awhile until possibly the failed component heats up enough to quit working. That'll be the green board in your pictures. Remove the EMI shield and lets see what is going on under there.
さんによる
Hi.. Did you fix your tv finally?
さんによる
14件以上のコメントを表示
コメントを追加
Hold down power button on bottom of tv for 10 seconds when it’s on.
このアンサーは役に立ちましたか?
スコア 3
9 件のコメント:
You are the bomb! This worked. Saved me a ton of $$$ and stress.
さんによる
Wow!!! Dude...I literally just did the same think (except with the remote) and it worked!!! What in the heck???? why? what was it can you elaborate??? but thank you soooooo much!!!
さんによる
Awesome. I did exactly the same thing and poof, problem fixed....
さんによる
Yes it works. But it hasn’t cured the problem. I have to do this 6 or 7 times to get my tv to turn on every time. Each time I get a bit further forward.
1. No reaction. Unplug and re plug in.
2. No reaction. Unplug and re plug in.
3. Logo appears and goes off.
4. Logo appears and a line appears at the bottom of the screen.
5. Logo then a still picture that fades.
6. Logo then a pic that moves for 1 second freezes and fades.
7. Works.
And I have to unplug it after the first couple of times or it doesn’t work.
さんによる
Mine just fades in and out
さんによる
4件以上のコメントを表示
コメントを追加
Had same problem with a LG 5510
Was watching TV and screen just faded to black sound remains
Logo comes on upper left for few second's then fades to black
Disconnected everything gave the back a good vacuum noted was dusty near some of the ventilation slots
Screen came back on after restart only been 10 mins but colour contrast vibrant looks good
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
So perhaps in my case was dust over power supply area??
さんによる
Mine did not have sound. Mine just died last eve, and each time I tried to restart it, I saw the LG logo, and my HDMI input info, and then it faded to black w/in 2-3 seconds. Unplugged, vacuumed, and dusted the ports, and then restarted. It did the trick! The set rebooted and ... Voila! Good to go!
さんによる
Now it s saying no signal
さんによる
My lg TV screen is fading to black after a few minutes on. The sound remains,but no visual from screen. Any help would be greatly appreciated
さんによる
コメントを追加
It’s a problem with the motherboard.
solution may sound extreme but it works.
Remove board and place in Warm oven for 20 minutes. Allow to cool , reinstall and all should be good.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
not helpful. I managed to squeeze my 16 inch telly into the oven and set the heat to 180 degrees, but this resulted in the plastic melting around the edges. perhaps 180degrees is too hot? tv still doesn't work. sad face
さんによる
I’m sorry to say that you must have misunderstood the instructions on how to do this procedure. You ARE NOT TO PLACE THE ENTIRE TELLY INTO THE OVEN FOR GODS SAKE MAN! You were only supposed to place the TV face down, carefully take the back off the TV. Unclip and remove clips off of the motherboard which is a square computer board that has soldering on it that needs re melted. You probably need a new Telly now.
さんによる
What's a good temp and how long? Is it the green board or orange? Is this something you've done before? I see nothing about this on the internet which has me questioning the whole thing. At this point im out of options.
さんによる
A good way to tell if you have one of these LG's is to look up the main board for that tv.. if it's hard to find that main board if it's sold out everywhere and even better if you find it but if they want ungodly amounts.. and if the LG was made in that time period I was talking about there's a good chance cuz they are rare and hard to find Main boards! If you want to know if you have one of these models, I'm one of two people in the entire world that offer a repair service where we do the repair right! You can find me at multiple personalities premium TV repair and services on Google or on facebook.. also Fire TV bullied on Facebook and I'm on my 4th semi getting large YouTube channel as Fire TV bully.. even the guys who were offering repair services and just throwing it in the oven we're charging more than I was. Lol! I started my business to help people so that's what I do! I can repair your existing board and I have dozens of those rare main boards available for sale
さんによる
How does someone get in touch with you?
さんによる
2件以上のコメントを表示
コメントを追加
the Led back light is bad, leds connected by series, one dead all will not work, check this video: https://youtu.be/LaV6aQ8LIpw
Update (11/17/2021)
If the logo showed for couple seconds then off then it could be the leds back light is bad, maybe just one of 40-10 less.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Our backlight is failing. Seems to be an issue with these LG TVs. Turns on, then screen goes black. Sound working and you can see screen using bright flashlight. We got our LG 60 inch working again by turning the backlight setting down using these options: Gear Icon > ... > Picture > Picture Adjust > Backlight. Our Backlight was set at 100. I would suggest putting your backlight at 10 or less NOW. We have it set to 6 and TV works again. I watched video on replacing the LED backlights and it is very difficult for not for a nonprofessional to perform. We had a bright non-LED flashlight to be able to see the screen to lower Backlight setting. Not easy with LGs stupid Magic remote. I will never buy another LG TV.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
You are a life saver I thought i had to throw mine in dustbin. What happened was my LED worked fine for half an hour and then screen goes black if i turn it off by remote and turn it on again It would turn on but this time it would only remain on for 5 mins max. By applying your method now the problem has solved so probably it was led light that was the issue.
さんによる
コメントを追加
I've been stressing about this. My tv would go dark only if the picture was dark or tv seen was at night so I would crop the picture and have a steady on background on the section that would go dark.
The other strange thing is that in initial setup mode the TV would stay on with perfect picture forever, but when done it would go dark again blank u can see picture only by shining a torch onto the screen and also barley.
But for the past week my picture has returned I no longer have to crop the screen everything is as it should be.
The issue was power, we unplugged alot electronics changed the multiplug and immediately saw a difference, check power supply to the socket as well
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have you tried a firmware update . It worked on mine for black screen no signal
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How do you update with a black screen?
さんによる
コメントを追加
This just happened to me. I always turn the tv on and off only with the remote and the tv remains on stand by. The logo came on when turned on by remote then the screen went to black and the sound was still working. While the set was still running I turned it off at the wall plug switch waited about 5 seconds then switched it back on and poof...picture working.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have this problem. Just out of the blue, faded to black and never came back.
Every time I power cycle it the logo comes on then the fade to black.
It is NOT a problem with the backlight since you can see the backlight moving when you move the magic remote.
It is NOT the mainboard: I tried changing to a new main board. No go.
It is NOT the power supply: I tried changing the power supply. No go.
The only thing left is the panel itself, but the drivers chips are literally attached to the ribbon cables of the panel.
So it's basically a 65" flat brick now. Bought a Sony Bravia, SOO much better.
I just really hate throwing this one into a landfill. >:{
I might try a heat gun gently to the driver chips on the ribbon, but I doubt that will work. I've seen several other posts about this same issue, but no one has really tried to go to the depth I did. The repair shop even said I've basically tried everything that can be done.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I have LG 55LA 6205 and problem is similar. initially stays on for about ten minutes and than video goes out and sound stay on. I checked the voltages going to the back panel and they are 135 and 183 at the the + point when the video is good than voltages drops down to 90 volts and video goes off. Any suggestions?
さんによる
I have a LG TV with model number 47 LA 6200 the screen is black too, but it has sound. When I turn it on the back light flashes and go off to a black screen. When I turn it off the back light flashes as well. When the TV is on and I shine a flashlight on the screen, I can see pictures moving. I tried the trick above by holding down the power button for 10 seconds when the TV is on but that did not fix the problem.
I took off the back of the TV to see components and when I unplugged the cable from TCON to the logic board, I hear sound and the screen is still black. When I shine the flashlight on the screen again there is no picture moving. I reconnect the cable and shine the flashlight again and see pictures moving.
Any idea?
さんによる
Hi,
I seem to have a similar problem on a samsung UA55TU8000U Tv.
It powers on alright menu etc all ok. And stays on. But as soon as a start viewing anything it goes off then reboots back to menu. (at menu without viewing anything it doesn't go off)
My email
chalohamisi@gmail.com
Whatsapp +254-772722582
Am in kenya
Thanks in advance
さんによる
コメントを追加
回答を追加する
Stan さん、ありがとうございました!
統計データ:
過去 24時間: 74
過去 7 日: 533
過去 30 日: 2,459
今までの合計 245,573
