Error!please plug out charger
Unfortunately system UI has stopped
Usually either the data on the system UI app needs to be wiped, firmware reflashed on phone again or factory reset via recovery menu which will wipe wipe all data on your phone.
このアンサーは役に立ちましたか?
No this most be from your charging port try to repair your charge port it it's isn't change the problem the check your phone battery connection or change new battery
このアンサーは役に立ちましたか?
過去 24時間: 6
過去 7 日: 7
過去 30 日: 18
今までの合計 4,402
1件のコメント
I changed the charging port, changed the charging board and even changed the battery, it was still saying error please plug out
Takeover Academy TV さんによる 共有
