メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年3月に発売された、Bluetooth接続対応のスマートウォッチ。モデル:FB502SBUL
Fitbit Blaze needs repair
The screen on my Fitbit keeps telling me to change the clock however the watch will not charge and the screen never changes from that message. Where may I get it repaired?'' ==
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
6 件のコメント
I wore my watch in the pool and now one of the buttons stopped working
さんによる
My blaze is not get charging even changing chargers
さんによる
Can you guys fix my Fitbit Blaze?
さんによる
It doesn't read my heart rate. The lights below the watch stop working. Is possible to fix it?
さんによる
my fitbit blaze screen went blank i can turn it off and on i feel vibrations but screeen is black
さんによる
1以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Hi @emrose ,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the watch’s operating design and could damage the components.
First do not turn on your watch and then you need to remove the battery as soon as possible from the watch to minimize any further damage.
Then you need to dis-assemble the rest of the watch and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the watch might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your watch
Fitbit Blaze
If this process seems too daunting, take your watch to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Contact Fitbit and they will tell you what to do
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Fitbit will tell you to upgrade to a newer model in a sideways manner. They will answer around the question ; when you read between the lines you realize they just told you to just buy another Fitbit.
さんによる
コメントを追加
I'd try the local cell phone repair place! My local place has some amazing guys who can fix pretty much anything! Alternatively, you can try you tube for a fyi solution
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike Cavanaugh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 1,971
