メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PS3に同梱されていたコントローラーの修理とサポート。2007年11月(日本のみ)および2008年(その他の国)に発売された、6軸検知機能とリチウムイオンバッテリーを搭載したコントローラー(CECHZC2)は、修理が容易です。
PS3 controller charging problems
When I connect my PS3 controller to the charger it doesn't start charging right off. I have to plug and unplug it so many times. I thought the cable might have a short but there is no pattern to when it starts charging. I don't know if I'm doing something wrong or if you have to do it a certain way. Can someone help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
OK guys I got it down to a science on why this is such a big issue. Basically older model PlayStation three controllers, especially ones with model number CECHZC2U absolutely need the Sony branded USB mini cable that came with the PlayStation three initially in order to charge. You can sync them to a PS3 using a regular USB mini cable, but not charge. Later models of the PS3 controller and third-party PS3 controllers allowed other third-party USB mini cables to sync and charge. So if you have the Sony branded USB mini cable that will charge all PlayStation 3 controllers via the system or an external USB 5volt 1 amp charging block.
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
Hi @alioop2605 ,
First use a strong light and a magnifying glass to check if the charge port enclosure is clear of any obstruction such as lint or dust. Also check that the pins are all there and that they straight and parallel with each other.
If there is any debris in the enclosure, use a vacuum cleaner to try and suck it out. DO NOT use a metal probe as you may damage the pins. If you have to dislodge any stubborn material, use a wooden toothpick to gently prise it out.
If it seems OK then perhaps the connector is loose on the motherboard.
Here is a link to the ifixit DualShock 3 マザーボードの交換 guide.
It is helpful as it shows how to dis-assemble the controller to get access to the motherboard. The USB charge port is clearly visible in the images in the guide from Step.7 on.
If the connector is loose then you'll need SMD (surface mounted device) soldering skills and tools to effect the repair.
If this seems a bit to daunting (the soldering I mean) take the motherboard to a reputable, professional mobile phone, electronics or laptop repair service and ask for a quote to resolder the connector. They have the correct tools and more importantly the skill to do the job.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Would it be cheaper to buy a new controller if I have to take it somewhere to get repaired?
Also thank you very much for the info.
さんによる 共有
Hi @alioop2605 ,
You're welcome.
I don't know what the repair price would be.
If you took just the motherboard (with the loose USB charge port either still on it or you still had it) to a repairer, the job itself would be quick. Since the repairer wouldn't have to dis-assemble / re-assemble the controller {that's your job} ;-) hopefully the cost would be reduced as there is less to do.
You can only contact them, explain the problem i.e. loose USB connector needs resoldering, if that's what it is and ask.
Here is a link to suppliers of same type controllers. You may have to do your own search on Ebay as my link shows prices in AUD Aust. dollars You can use your search results as a comparison with the cost from a repairer, (try a few) and then make a decision that suits you.
Cheers.
さんによる 共有
コメントを追加
Plug it into your phone or laptop it's sure to charge then mine only charged for me this way
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Trying to charge on the desktop worked for me , thanks!
さんによる 共有
Didn’t work for me I tried everything my computer, tv, PS3 USB wall
さんによる 共有
コメントを追加
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tia Autrey さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 34
過去 30 日: 264
今までの合計 35,272
