メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy S5 SportはSprint専用のフィットネス愛好家向けに設計された端末です。
Replacement screen pops off up top
Hi, I recently replaced my Galaxy S5 screen and the glass keeps popping up on top. I can re-heat the screen and press it down for a few minutes and it stays down. However within the next day it starts popping up. Anyone have any ideas? This is also happening on my ipad.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Either not enough adhesive put on or adhesive being used is too weak.
For the iPad if the adhesive is strong enough, the usual cause is the dents on the iPad frame's metal corners that would need to be bent back in place.
B7000 Glue is usually used in cases like this where the corner keeps pushing up. The glue takes about a day to set in well with tape to hold it in place for it to set.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for replying. I'm going to try this glue out and post back what happens.
さんによる
The trick is to lift up the screen (on the weak spots only) just enough to put the B7000 glue in, don't put too much of course. Then apply pressure on it and use something like scotch / sticky tape to hold it down.
Then wait for about 24 hours. Take the tape off and rub off the excess glue.
さんによる
コメントを追加
回答を追加する
kristian Burns さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 1,102
