メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ハードドライブ(HDD)の修理情報。ハードドライブは磁気データ記憶装置です。低コストかつ高データ密度であることから、ほとんどのデスクトップ、ノートPC、サーバーで使用されています。
Can HDDs operate upside down?
This may be stupid and obvious but, I have a hard drive that putting it in my desktop upside down would be better for cable management. would it work (reliably) upside down? it's probably a yes, but I'd rather not kill a perfectly good hard drive if not. (especially with data on it.)
@danj or @oldturkey03 I think you might know this.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
It depends on the size and the age of the drive!
A 3.5" is designed to be mounted either on its side or flat with the top of the drive up. While you can run it upside down it's not something I would do as its normal position. In the case of older drives - I wouldn't alter the basic mounting. If you do mount it differently its a good idea to reformat the drive so any slop in the heads will not mis-write or read. Moving the system or banging the drive can crash the drive very easily when its running.
2.5" drives are less sensitive on it's mounting but just like 3.5" drives moving or banging the drive can crash it. most laptops have crash guard protection systems so the head assembly is parked before any damage when the system is banged when running.
In any case make sure the drive mounts are cushioned.
このアンサーは役に立ちましたか?
スコア 5
41 件のコメント:
In my dell the hard drives are upside down and they work fine.
さんによる
What is the size of the drive? I bet you its a 2.5"
If you replace it I would review the spec sheet of the drive you put in to see if it makes any note on mounting.
さんによる
@danj All Dell computers have drives either sideways or upside down on the business lines of computers. Only Ancient 3.5" may have had issues running upside down. Those were like ....10mb (not gb) hard drives. As a matter of fact, i still have one of those ancient Western digitals. You had to actually run a DOS command / program to park the hard drive head before turning off the computer.
さんによる
@avanteguarde - That was my point! A 2.5" drive wouldn't have as issue running upside down. Only the older 3.5" drives.
Even still its smart to format the drive and run it at the same direction so there is less risk of error from head slop.
さんによる
It has two 3.5. One original 80GB and one 2008 iMac 250GB hard drives.
さんによる
36件以上のコメントを表示
コメントを追加
最も参考になった回答
Yes, they can operate sideways, upside down, port side down etc.
このアンサーは役に立ちましたか?
スコア 6
8 件のコメント:
Thanks! I'm always paranoid with HDDs
さんによる
@avanteguarde one more thing... Is it OK for an HDD to be right under a DVD drive? I remember pulling apart a DVD player and finding a magnet inside.
さんによる
Yes, it is fine.
Hard drives are shielded. Just don't put a real magnet directly on the hard drive.
さんによる
@captainsnowball There is a strong magnet in hard drives too so it’s more than fine.
さんによる
I see where you're coming from, but that magnet is very tiny so it can not destroy the HDD.
さんによる
3件以上のコメントを表示
コメントを追加
Yep, you can have them up side down, perpendicular to the bottom of the case, at 45 degree angles are not recommended. The most important things are making sure they're secure and that their temps are cool enough.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Aiden さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 93
今までの合計 39,322
