メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Flip 4ポータブルスピーカーは、CESイノベーションアワード2017を受賞したIPX7防水Bluetoothデュアルドライバースピーカーです。
Connect + no longer opening since iOS update
For some reason ever since the update to iOS 11.2.5, my JBL Connect + app (that previously worked fine) no longer works. It now starts on a screen that directs me to turn on the Bluetooth on my iPhone X, despite it already being turned on and paired with the speaker.
No matter which order I do things in (I’ve tried turning off Bluetooth and then starting it when the Connect + app asks for it, but it still doesn’t think I have Bluetooth turned on).
I’ve tried restarting my phone, telling it to forget the speaker(s), resetting the speakers to their factory settings etc. No dice.
The main issue I have is that I use two Flip 4’s for the stereo feature but I can’t turn that on unless I can access the app.
Can anyone help or has anyone else had problems since the iOS update??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
If your JBL Flip 4 speaker refuses to connect to another device through Bluetooth, see the JBL Flip 4 Won’t Connect Through Bluetooth problem page for possible causes and solutions.
Try:
a) first uninstall the app
b) go to Settings --> General --> Reset Network Settings
c) completely power the phone off after it resets and reboots
d) download the app again, and try pairing blu tooth from scratch.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Sorry for taking so long to respond but your solution totally solved my problem. Thank you so much for taking the time to help out. I really very sincerely appreciate it.
さんによる
worked for me too, thanks
さんによる
Perfect , but restarting after reseting was for my iPhone X and charge 4 not necessary
さんによる
コメントを追加
回答を追加する
Max F さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 21,036
