Does your JBL Flip 4 speaker refuse to connect to other devices via Bluetooth? JBL Flip 4 speakers are susceptible to a range of problems that can cause their Bluetooth connectivity to fail. Check the following causes to identify and solve the problem.
Speaker is Connected to Another Device
If another phone, TV, or computer that has connected to your speaker in the past is within Bluetooth range, it may have already connected to your speaker, thus not letting your preferred device to connect. The JBL Flip 4 can only connect to one device at a time. To fix this, try to find this intercepting device and disconnect the speaker from that device.
If you cannot find the intercepting device, try to isolate the speaker and your preferred device. For example, you can try going in a closed room far away, to physically disconnect the speaker from the intercepting device. Turn off the speaker and turn it back on and allow your preferred device to be the first device the speaker finds to connect with.
Interference From Nearby Devices
If a device near your speaker is sending signals with the same frequency used by your speaker to connect via Bluetooth. These devices generally include WiFi routers, baby monitors, or other wireless speakers. To fix this, move any barriers around the speaker that could be interfering, or restart any device that could be causing the interference.
No Bluetooth Audio Driver
If a computer does not have the software required to use Bluetooth, the Bluetooth device might have trouble connecting to computers. Most computers should have the standard Bluetooth audio driver that the JBL Flip 4 uses. If your computer does not include the required Bluetooth audio driver, refer to your computer’s manufacturer to download the required audio driver.
Questions other people have asked about this
- Locating and disabling bluetooth on a JBL Flip Essential
- Why is the sound of the JBL Flip 4 turning off or not working at all
- Connect + no longer opening since iOS update
- JBL Flip 4 doesn't search for Bluetooth devices.
- Bluetooth Range & Connectivity Issue
- Cannot pair, cannot find “available device” in my iPad Pro
0 件のコメント
