メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日にAppleから発売されたiPhone 6sの修理情報およびガイド。モデル:A1688、A1633
Inaccurate GPS while moving
Hello,
I bought used iPhone 6s in perfect condition, but I've got problem with it. I'm a runner and I use GPS trackers a lot. I tried to change the app from Endomondo to Runtastic but there was no effect. My tracking is full of waves and it is "rounded". I installed app called GPS Status. It shows sometimes my position with 10m accuarcy but the most of the time there is +-65m and even if the phone is not moving it shows speed occasionally. What should I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
Hello,
i would advise you to swap out the internal antenna it's weak and internal antenna isn't so expensive so go for it. Guide and every thing will be down below. If you don't have tools required to oppen up your device i will also post that down below.
Internal antenna:
iPhone 6s Wi-Fi Diversity Antenna
Tools:
Pro Tech Toolkit
or if this is too expensive you should buy this next tools:
画像
you can find this tools at this link but just scroll down to tools:
iPhone 6s
EDIT:
Forgot to paste the guide link so here it goes:
iPhone 6s Plus の上部左側Wi-Fiアンテナの交換
The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions.の画像
製品
Pro Tech Toolkit
$79.95
Replace the Wi-Fi Diversity Antenna compatible with the A1633 and A1688 model iPhone 6s smartphone. Fix unreliable connectivity to Wi-Fi signal.の画像
製品
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Ok, thank you very much. I will tell later if it work.
さんによる 共有
I see you are new to this site so if my answer is correct you chose my answer for solution. If not you can wait for someone else to answer. And if some how good point you can up vote it. Hope it works.
さんによる 共有
コメントを追加
Hello,
I've changed the diveristy antenna, but it didn't help. The GPS is the same inaccurate as it was. Should I check something more?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
iPhone 6のアンテナフレックスケーブルの交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
GPS tracker and network
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Michał Wijata さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 1,487
