メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
Error 4013 iPhone 6
The iTunes will stage, 'waiting for iPhone', and then into, 'preparing software for iPhone'. I will then go back to 'waiting for iPhone' and crash, ending in error 4013! It is otherwise in a constant loop. I cannot access and settings!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 16
3 件のコメント
1. Do a Factory Reset of your iPhone Device
2. Clear Cookies, Cache, and History from your iPhone Device
3. Reset your iPhone Device
4. Use RecoveryTool
http://bit.do/exGXL
さんによる
Will this get rid of that code and make phone work with no further issues or once the error has already popped up are you screwed ?
さんによる
Iphone 6 getting same error 4013. I just replaced broken screen and display ok but since getting error 4013. new part in good condition as well try almost 4 computers still same! Only thing diff is miss the metal part above the display cables. Can be cause the 4013 issue ?Appricate your help! Thank you
さんによる
コメントを追加
6件の回答
ベストアンサー
Error 4013 is a board level issue that only people that have micro-soldering skills can fix.
This may involve one or more of the following:
- Removing the NAND memory chip and reprogramming it
- Diagnosing and fixing the power circuit(s) going to the baseband or processor.
このアンサーは役に立ちましたか?
スコア 11
1件のコメント:
Check the condition of CPU power supply or components on power supply rails. Or check if the CPU is pseudo soldered or damaged.
Here we have a repair guide for fixing iPhone 7 error code 4013 for your reference: https://blog.rewatechnology.com/how-to-f...
さんによる
コメントを追加
This error could be due to multiple issues, In short the error is a connection error that is telling you that there is a communication issue between the device and the PC. Here are some solution
  1. Try a different cable, preferably an official Apple Lightning cable
  2. Try a different USB port
  3. Clean out the Lightning port, lint is sometimes in there not allowing a good connection, use a pick to clean it up
  4. Try a new charging port, sometimes these port get worn and need replacement. This could be causing that error
If all of these are tried and it still doesn't work unfortunately you have a motherboard issue which unfortunately would need a motherboard repair which most often is not cost effective. Hope this helps, best of hopes!
iFixit iPhone 6 Lightning Connector Guide
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Using Joyoshare UltFix can repair your iPhone error 4013 without data loss. I have tried myself.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Download Reiboot on your PC and connect iphone to pc. Then click on “Exit Recovery Mode”. Thats it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
but my iphone 6 ill still error 4013 again
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
did you try Reiboot?
さんによる
コメントを追加
i got same issue always Stuck on iTunes. Then Imyfone they help me out repair it and now working fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cody Potato さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 50
今までの合計 35,458
