メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年12月に発売された、アジア市場向けのSamsung製Androidスマートフォン。多くのモデル番号が存在し、SM-A5000、SM-A5009、SM-A500F、SM-A500F1、SM-A500FQ、SM-A500FU、SM-A500G、SM-A500H、SM-A500HQ、SM-A500K、SM-A500L、SM-A500S、SM-A500YZ、SM-A500Y、SM-A500Wなどのモデルが含まれます。
How to switch off device experiencing a bootloop?
I messed up a TWRP flash and the phone is stuck in a boot loop, I know why the flash failed and that reflashing it to stock should fix it. Though there's a problem. The home button does not work. So far, I've gotten around that by booting to recovery and bootloader using adb, but that doesn't work with it sitting on the "Samsung GALAXY A5" title screen. I know that the home button needs to be fixed to get anywhere with this, but what's worrying me is that there isn't a way to switch the phone off. Holding down power or power + volume down does nothing but send it into another cycle of trying to boot.
Should I just let the battery run out? Looks like it'll keep going for some time since it was on full charge when I did the flash. It will be some time before I can get the home button fixed and don't really want the phone vibrating every 2 minutes for what will probably be days.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hold power, volume down AND home for 15 seconds. It should initiate a force shut down.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
hehe I know, though the problem is that the home button doesn't actually work, the board that has the charging port, back and menu button needs to be replaced.
Thankfully the battery died in the night, so can either see if the power down helped in anyway or wait to get the home button repaired.
さんによる 共有
i have the same problem in my gionee s6s .....what should i do ?
please help..
さんによる 共有
i have no homr button tho and when i press and hold volume down and power key it just reboots my phone faster!!!
さんによる 共有
コメントを追加
回答を追加する
Liam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 10,328
