メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsungのフラグシップスマートフォン、Galaxy S8。2017年4月発売。
How do I remove Samsungs Live Demo Unit Software?
Hello all! I have recently bought a lot of samsung smartphones on eBay. They are all Live demo Units. I am aware that there is no baseband in this phone and no IMEI assigned to them so it will never be able to connect to a cellular network but im getting really annoyed with the live demo software and would like to know how to remove it. I would flash with Odin but im on a MacBook Pro so thats not an option.
The phones are:
Samsung Galaxy s6 Edge (SM-G925x)
Samsung Galaxy s6 (SM-G920x)
and...
Samsung Galaxy s8 (SM-G950-XU)
Thanks!
Also don't bother saying return it because the screen of the s8 is worth the same that I paid for all of these. ($200 CAD)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 22
18 件のコメント
Same. I know the passwords but they don't do much. I tried to remove it but it comes up with a reset button and if you press it it will factory reset the device but retail mode comes back. passwords - 5444 and M729Q16K8546. And I have a galaxy s8+
さんによる
How to Remove Demo Live Forever Trick
さんによる
Hey I need help. Can I email you?
さんによる
Most of your devices are stolen but you can remove Samsung demo mode it easy
さんによる
@big_m_h how? I bought s 10 and realised day after that is demo unit. Is there solution to fix that issue?
さんによる
13件以上のコメントを表示
コメントを追加
13件の回答
ベストアンサー
http://forum.gsmhosting.com/vbb/f453/g92...
Check post #10.
You may be out of luck on the demo unit models as the firmwares probably have hard coded live demo app installation even after factory resetting / wiping the phone.
このアンサーは役に立ちましたか?
スコア 12
1件のコメント:
For that I was able to download this application in the App Store and it does do a factory reset but the ldu software auto loads itself.
さんによる
コメントを追加
This may not help but here are the passwords for retail mode. passwords - 5444 and M729Q16K8546.
このアンサーは役に立ちましたか?
スコア 8
10 件のコメント:
Password from Best Buy US units I think is "blue".
さんによる
Sprint is "unlimited"
さんによる
walmart is "rollback"
さんによる
Tracfone is halfthecost
さんによる
Do y’all know what it is for Costco?
さんによる
5件以上のコメントを表示
コメントを追加
you know what all your answers are wrong. also checked on other forums the 5444 and m729 is only use to access retail mode app in order to set ldus settings and also to register the store where the ldu is being setup.. i have a friend from samsung and good thing he’s from hhp fieldforce he taught me how to disable or freeze the retail mode inorder for user to use the ldus but take note you can only use it like tab you can download games and store files like ordinary tab or ipad without sim. so here it is
you need the 5444 and m729 to open retail mode app
  1. on the retail mode app on the upper part you will see the “3 dots” like settings drop down you’ll see 3 items there. now go back
  2. here is the trick. on the lower part right at the middle of your screen just tap your screen there 9 times. dont worry at your 6 tap youll see a notif to click 3 more 2 more 1 more ..
  3. then voala!! go back to the 3 dots on the upper right part open it and youll see now 4 items the last item will be deactivate retail mode, tap deactivate then it will turn to activate meaning its already deactivated
now to fully use the phone you’ll see also under option the lock/unlock auto factory reset. you need to turn it off so that your phone will not factory reset every day during 9am gmt lols..
—-owkey hope this one will help you. been using s8+ ldu for a year now. this one applies to s8 to note 9. and to s7 and lower i hope you will find the retail mode global neutralizer i guess the file is being leaked ol where in you download the apk file install it and it will corrupt the retail mode app and automatically freeze the retail system that s been hard coded into the ldus. i dont have the file myself but my friend does since he is using s6+ ldu before..
このアンサーは役に立ちましたか?
スコア 6
7 件のコメント:
Hi Albus DUMBledore
@santopapa00006 what is the password to deactivate retail demo. Tia
さんによる
what is the password for deactivating? because it asks for the password,I have tried to enter those passwords but they are all refusing!
さんによる
The m729 password doesn't work for me and then when I tap the three dots I only see two options not three is there a way to contact you directly
さんによる
How to enable security mode in a demo samsung?
さんによる
What you've said looks true more than everything here. But there's a demand for admin password which you didn't include. Please help drop the password to deactivate the retail mode. Thanks a lot.
さんによる
2件以上のコメントを表示
コメントを追加
You can remove Retail option in this phone but can't use sim, for this sim issue you have to use extra device ...which is called Gmate Smart
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
what,s the full name of that device and from where i can get that
さんによる
コメントを追加
You can still flash.
Call on Heimdall, and tell him to activate the bridge.
Use Heimdall instead of Odin.
Here is a tutorial.
https://forum.xda-developers.com/showthr...
_________
Here is a iFixit thread on disabling Retail Mode.
How to remove retail mode?
I'm not sure if its in this thread, but I've read somewhere even though you can remove the demo software, the phones are neutered so they can't make calls.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
It is also possible to install windows on a mac using a method called bootcamp without the need of wiping Mac OS X as it can split the storage drive into separate partitions, one for MAC operating system and the other for Windows operating system.
さんによる
I know about that but i only have a 120 gb ssd and 100 gb is takin up...
さんによる
コメントを追加
Password for phones from Sam's Club is "Walton". It works, and although I understand I can't use cellular, this is becoming less of an issue everyday, as I live in a city and everywhere there are hotspots and many apps to take advantage if free WiFi calling and texting. .....BUT...The software demo keeps coming back intrusively. And it won't update the security policy so that popup is a constant problem.
On the good side, the phone was a demo that I bought off a dude on the street, for a very reasonable price. I'm sure he came on it through honest means because he told me so repeatedly.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
What if you change the motherboard ,will it be still showing the retail demo or it wont work.?
さんによる
since all the hardware and software is on the MB yes a swap would solve it which is what we do all the time, if we have a good lcd but bad mb and one visa versa a swap makes a complete phone.
さんによる
reset after this enable eom unlock in developer options after open download mode install new kernel im using from s6edge plus exynos.tar md5 after this some times you need install new software and you have normal phone just Samsung haelt and Samsung pay apps no works anymore but play store and ewery thing be like normal phone
さんによる
コメントを追加
I have a Sumsung Galaxy s7 Edge which is a “live Demo Unit" I have factory restored the retail firmware and it is free of any reference or behavior of the demo unit.
Before you do anything, make sure you have backed up your device to google cloud, smart switch, or Samsung Keis.
Also make a note of the IMEI number and Serial Number if you want to flash a working model. Sometimes these can be erased and will need to be flashed afterwards, although I have only encountered one such occasion this was needed from the dozens of phones I have updated firmware on.
It is relatively easy to restore the device to factory retail state by following the following instructions:
1) Start the device in Android Recovery Mode
2) Wipe cache partition, then,
3) select Wipe data / Factory reset
4) power off device (If you fail to follow steps 1-3 before doing step 4 onward, the process may not be effective)
4) Go to https://www.sammobile.com, find the exact model you have and download the latest firmware for your country. Any Carrier version. Download and unpack zip file. Make sure it is the exact model. If you cant find it, You can be safe using a version that has the “F” immediately after the model. eg: SM-G935FXXU2EREM where F is designated as “Global”.
5) Download Odin software, install it, and run the program.
6) select each of the BL, AP, CP, and CSC options one at a time from the firmware folder. The AP file could take a while to load depending on your computer configuration, so please be patient. Do not select the CSC HOME option. If you do select the CSC HOME option you will have to flash the device again from step 1 because all your apps and user preferences will not be affected and that means many demo features will not be removed.
7) Start phone in Download mode. Connect cable (It is very important that you make sure it is the original Samsung Cable), then press the volume up key to start Download Mode. (If all is correctly done, the Odin log window should show device is added).
8) Click Start in Odin and wait for the process to finish. This will take a while. If successful the box in the top left should go Green and say Pass.
9) disconnect phone from cable before restart completes. If the device doesn’t restart correctly, reboot the device. It should be working just fine. Of course it is now a fresh new system and will need either a restore of your device from google backup to reinstate your apps etc, or setup from scratch.
Everything should work as a new device out of the box with the exception of the cellular service. I use mine as a MINI tablet. works great around town on hot spots for Google, Google Maps, Skype, Whats App, Facebook messenger etc..
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
^ YES! Kinda jerkish to give us this trick (and of course this is the only place on the web I’ve found that this is posted) like finding the hidden deactivate button … and then not giving us the pw. RAWWWWWRRRRRRR!
Regardless, if you disable factory reset using the aforementioned passwords, delete the hidden files, go back to main menu and disable content protection then go to settings/apps/special access (under the menu at top right)/ device administrators you can can uncheck the retail mode app and deactivate that way.
I also denied it permission under apps that can change system settings just for good measure.
Get Package Disabler Pro (Samsung) in play store and disable both retail mode apps (samsung and retailmode), Discover S8+ and anything knox related (also just for good measure).
Easy.
I dunno, but after 24 hours or so it seems to be fairly retail mode free, and I didnt touch Odin. With the retail mode service gone, i cqn charge past 70%, power saving mode and airplane mode work fine, obviously cell radio/SIM reader isnt even in the phone so i cant make calls, and factory reset is still missing, but why would I wanna go thru all that again anyways? I just got a $50 S8+ with some minimal tweaks. I’d say thats pretty rad.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
can you put sim on that as well?
さんによる
コメントを追加
try this tut; https://forum.xda-developers.com/galaxy-...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What is targets passcode?
さんによる
I also need the Targets passcode.
さんによる
コメントを追加
I have a j36 and booting in safe mode, I then sign into play store to download apps that won't work in safe mode yet, and enter settings to disable any thing Samsung with storage permission .also I force stop/ disable Knox and retail agent such and such apps, and make a lock pattern reboot to normal for 1 second and remove battery quicklike so retail demo can't start yet,(@ the lock pattern screen, and reboot again to safe mode enter my lock pattern , then amazing!?! Still signed on to play store & in app folder are icons minus the graphics what I then does my self th courtesy of moving to home screens and Bing bang boom the app works , any app . I don't use SIM but my apps work I stay signed in and no screen saver every minute better than I've heard of any one else yet cuz the pswrd don't work for me . And personally on a Rogers phone I put in a telus sim , it asks for a network unlock code, It'll probably accept chatr
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You could try jodin/Heimdall, a Java based version of Odin for Mac and Linux, though my experience with it was that it hasn't been updated to reflect the current version of Odin and it never worked properly for me. Probably it would be better to just run Odin for Windows through VirtualBox or parallels desktop, that's been my preferred solution on any reasonably powerful Mac or Linux computer. You just have to make sure USB is configured properly in the virtual machine, there's tutorials about it on the virtual box website, and I'm sure parallels explains the process with that solution on their site too.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I did exactly whate Shane Walls-Harris (⬆️ 2) did & it worked for me. All is good except cellular data
さんによる
コメントを追加
I have an eBay Galaxy a15 5G Demo Locked.
Any chance of salvaging this?
画像
画像
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It's been a long time since I played with these phones, sorry but no or maybe yes it depends on what you want out of it. These phones as far as I'm aware don't have any way to access mobile data, if you can find the way to disable the retail app you can have a basic phone maybe for a kid or a wifi only phone you don't care about breaking (which is what I did... Lots of under water pool or shore pictures). There is a app I think it was called apk disabler Samsung? I used that and disabled the retail stuff so it wouldn't remove pictures or apps but if you do a factory reset it comes back. I also tried Odin but no luck, I bricked the device :/ the devices I had was the Galaxy S8+ S8 and S7
さんによる
Rereading this thread, I was wrong with apk disabler it's called package disabler. NV NN talks about this above
さんによる
コメントを追加
I have a Samsung Flip 3 that was demo locked. I used the newest ODIN to install the first or second version of an unlocked US CVC code. It only worked as a WIFI phone and my IMEI Is still just a bunch of zeros, but I'm good with that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ethan Leroux さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 63
過去 30 日: 338
今までの合計 219,942
