メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
774回答 すべてを表示
Broken display - where can I find the right display to buy and change
I have broken my display. It is not the glass that is broken, but something inside in the upper left corner. In the Apple shop I have been told that it would cost around 900 EUR, and that is a little bit tooo much!
I found the guide to change it by myself here on ifixit, but I am not sure where to buy the correct display for my Macbook pro 15'' Retina Mid 2015..
And also, I am kinda scared to actually do the whole replacement by myself, since there are many steps and it could be dangerous for the rest of the laptop.
Please take a look at the picture: Picture
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I suggest you find the serial number of the LCD and look it up online i.e. ebay, craigslist.
Doing everything all by yourself is a risky gamble.
It can be, both, disappointing and rewarding depending on the outcome of your tinkering.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Yes, indeed you broke your LCD screen you can see the line of the panels base sheet which is the crack. You likely banged the corner or something dropped on the lid. Surprisingly the cover glass has a rubber gasket which softened the blow so it didn't crack.
I would recommend replacing the complete lid assembly Vs the discreet LCD panel here as we don't know how bad things are on the inside and its a lot more work.
Here's the IFIXIT guide you'll need to follow: MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement and here's the part you'll need: MacBook Pro 15" Retina (Mid 2015) Display Assembly.
It's not that hard as long as you take your time and follow the guides. Just be delicate with the connectors are they can be broken with little force.
MacBook Pro 15" Retina (Mid 2015) Display Assemblyの画像
製品
$519.99
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
I must not fear.
Fear is the mind-killer.
Fear is the little-death that brings total obliteration.
I will face my fear.
I will permit it to pass over me and through me.
And when it has gone past I will turn the inner eye to see its path.
Where the fear has gone there will be nothing.
Only I will remain.
Frank Herbert
さんによる
Are you into ScFi novels @mayer ? I loved Dune!
さんによる
@danj I read all the classics in my youth. Boxes full of paperbacks.
さんによる
@mayer - I read the first three of the six book series. The first is close to 900 pages!
さんによる
@danj that's all you really needed to read. All the rest (the next the and all the subsequent ones that are still being written by his children and others) were for money. The Dune trilogy was really his magnum opus. But I really did like "The Eyes of Heisenberg". I love that since 2009, the names of planets from the Dune novels have been adopted for the real-life nomenclature of plains and other features on Saturn's moon Titan.
さんによる
コメントを追加
回答を追加する
Adi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 84
