メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Inspiron 11 3147は、11インチのノートパソコン兼タブレットのハイブリッドデバイスです。画面を背面に折りたたむことで、手持ちで使用できます。2015年8月にDellにより製造されました。
Three beeps upon startup
Does not boot and instead get three beeps. Given three different possible solutions: Chipset Error (North and South bridge error)
Time-Of-Day Clock test failure
Gate A20 failure
Super I/O chip failure
Keyboard controller failure
How would I go about testing which one of those would be causing the issue? The website says to run Dell's diagnostics tool but it won't even boot up far enough for me to access that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@inlerah start by removing the battery, the AC adapter and the RAM then hold the power button down for a while. Replace the AC adapter and see if it starts up. You also want to try a USB keyboard and see if that makes a difference. If not then I would suggest that you replace the RTC battery first and try to start it up after that. Use this guide Dell Inspiron 11-3147のCMOSバッテリーの交換 for that.
Any of this
Gate A20 failure
would require boardlevel repair and for that you need to let us know what exact motherboard your computer has.
Update (10/21/2017)
@inlerah have you tried a different memory module? You do want to rule out that you have a bad module. Your motherboard should have a few numbers silk screened on the board. Just give us those numbers or post some really good pictures of your board with your question. You can use this guide iFixitでの質問に画像を追加する方法 to do so.
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Dell Inspiron 11-3147 CMOSバッテリーの画像
ガイド
難易度:
簡単
10 minutes
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
(Late response, had to wait until drivers of the right size got delivered) So I did this and I got back a "No ram detected" beep code. Where should I be going from here?
Also, I can get you the motherboard type...just need to know where to get that info from.
さんによる 共有
コメントを追加
回答を追加する
William C Ward さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 858
