メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon EOS Rebel T3は、Canonのエントリーレベル一眼レフカメラであるRebelシリーズの系譜を受け継ぐモデルです。EOS 1100DやEOS Kiss X50としても知られており、12.2MPのイメージセンサーとDIGIC 4画像処理プロセッサーを搭載しています。
How to fix error 30?
I am getting this error message Shooting is not possible due to an error
I need help please.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I need to I have camera canon 200d please help me error30 problem coming
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
Hi!
The following text has been quoted from the Canon forums, someone had a similar issue and this is what the rep answered:
"Err 30" indicates that malfunctions related to the power source have been detected. Please follow these steps to attempt to resolve the issue:
Remove the battery from the camera.
Using a soft microfiber cleaning cloth, thoroughly clean any contacts that you are able to clean on the battery and inside the battery compartment. Do this even if the contacts already look clean.
Retry the battery in the camera.
If the error still occurs, please try an alternate battery. If the alternate battery produces the same results, your camera will require service to correct the issue."
Hope this helps.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
This can also be cause by contaminates and mainly shutter issues, see the many answers on this post:
Camera gets Err 30 message. How do I fix it?
さんによる 共有
It’s a faulty shutter.
さんによる 共有
コメントを追加
Also monitor its environment
that could easily create this issue.
Like leaving camera or any delicate device
in hot/damp enclosed vehicle.
They can be easily forgotten there,
exposed for days.
Good Luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'd first start with the other troubleshooting methods in the other answers, with checking the battery. However is seems like this error is often times caused by a bad shutter and there is a fair chance the shutter assembly will need to be replaced.
Definitely rule out any other possible causes first, but if it is deemed the shutter is the cause, you can use this guide to replace the shutter assembly. It's not the easiest repair to do, as it involves disassembling the majority of the camera (including the image sensor), but it is doable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Herve Dingi さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 54
今までの合計 21,767
