メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年6月8日に発売。A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor.
Muffled Microphone - iMac 21.5" (mid 2017) - Following Adhesive Strips
This is actually an answer rather than a question; a solution to a problem that is not yet in any guides. Since I couldn't find a resolution online, I figured I'd share my own.
The mid 2017 21.5" model of the iMac is new and this issue isn't major, so it's not surprising that the few people who have sewn up their computers after an upgrade or fix either haven't encountered it yet, or found the true cause.
The problem is that after reassembly, the microphone input is faint and muffled. It functions, but barely, and is essentially unusable. The culprit turns out to be the adhesive strips used for reassembly. The frame of this iMac model seems identical to its 2012-2015 predecessors, so ostensibly the same strips made for these earlier models would work here too. However, the microphone has been moved from the top of the computer (near the webcam) to behind the frame at the bottom of the screen.
Note the location of the "4R" strip in the following picture:
https://d3nevzfk7ii3be.cloudfront.net/ig...
Now look at the location of where the microphone has been moved to:
One can clearly see that the "4R" strip completely covers the microphone and the holes in front of it, deadening any sound picked up.
Knowing this, the solution is simple. Make sure the microphone works properly before using any adhesive. Then, apply the adhesive strips, but when laying down the "4R" strip, cut away the portion covering the microphone (and a little bit more from each side to be safe).
Hopefully, this post will save others from hours of exasperation! :)
Cheers!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 67
44 件のコメント
2 weeks at AppleCare, still not resolved. Have to take back. Losing money on freelance every day!
さんによる
I had the exact same issue with the 2017 27" iMac. This post gave me a clue of what was going on. Thank you!
さんによる
Thank you very much! your post saved my time too :-)
さんによる
Not received this type of iMac yet, but a big thank you for the heads up as this is easily overseen!
さんによる
Thank you very much!!! This post saved me a lot of time.
さんによる
39件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
@iofile Better go here and create a technique tutorial about this it will be more efficient than a answer in a question. If you dont want to do it just tell me and I will enjoy doing it in your place.
このアンサーは役に立ちましたか?
スコア 10
12 件のコメント:
Yes, I would love to write a guide on this. The only complication is that I'm out of town atm, so it would probably be a couple weeks before I could write and post it. Is this an acceptable time frame?
If you think people could benefit from having this information sooner, then perhaps you should tackle it. Thank you for the interest!
さんによる
Can you tell why strip is covering the mic? Can it be while producing computer? Or it is 100% physical modification by users? I ask that because suspect that the person who sold me a "new" iMac might fool me. BTW I have iMac 2017 5k Z0TR/5 model
さんによる
@bora89 this happens when you open your Imac and you gonna use another adhesive tape to reseal the machine. What seem to be the problem with yours?
さんによる
Yes, it is muffled. But I did not open my iMac, I bought "a brand new iMac" that I was told, all the one way unsealing tapes were on box. I just do not understand.
さんによる
If is brand new you can check you warantie coverage for it , if is still in warranty just get it changed by Apple https://checkcoverage.apple.com/
さんによる
7件以上のコメントを表示
コメントを追加
for future fixers, here’s some verification of the above info. The first photo is how I found the adhesive as soon as I peeled it off, clearly a clean cutout of the adhesive from the factory for the microphone. And then the second photo after I uncovered the other two holes.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
Hi! For anyone who ends up here in / after 2019, our iMac Intel 21.5インチ Retina 4K Display (2017) 接着ストリップの交換 guide accounts for this issue, and all corresponding procedures link to that guide. Happy fixing!
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
I just use a single hole paper punch to cut out the needed area in the tapes. It doesn't take that much of a cut.
さんによる
In the iMac 27" guide I did not find any hint for this.
I upgraded Blade SSD and CPU on my iMac 2017 with the corresponding guides and now I have to remove the screen again and buy new tapes.
さんによる
So I did not realize Apple moved the mic from the top of the iMac frame to the bottom of the aluminum frame. The lcd actually covers the mic location and the double sided adhesive tape holds the lcd in place. The tape will cover the mic if you don’t cut the tape to allow for the mic. So I removed the lcd and discovered that my tape job covered the mic. I removed the tape around the mic going a 1/2 inch out on both sides.
I closed it completely up but didn't apply new tape yet, tested the mic and it still sounds odd, better than the first time I closed it (there were echos and screeching) but still not right.
Has anyone replaced the mic yet?
さんによる
macisgr8 Exactly my problem. The mic picks up after tape removal, but not as good as it was And sounds like I’m in the bathroom.! What could have happened?
さんによる
@macisgr8 Hi I have exact same problem, removing adhesive not helping the mic. Did you find any solutions yet?
さんによる
1以上のコメントを表示
コメントを追加
Eve Ann Wallis - This series has a unique issue! Apple moved the microphone hole! And in doing so have messed up a few people. You need to modify the bottom tape with a small cut out so the hole is not covered. Here’s the location of the microphone hole:
At this point you should get another adhesive tape kit and after fully cleaning the old tapes off, modify the new set as needed but cutting a small area at the bottom edge of the strip where the mic is and give that a go!
But, before you put the display back on check your mic cable is connected properly as outlined in step 57 in this guide and the ribbon cable is not damaged iMac Intel 21.5インチ Retina 4K Display (2017) ロジックボードの交換
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for this, it's most helpful. I've already ordered new adhesive strips. Funny thing is that today the external drive is recognised in disk utility but not in Finder, whereas yesterday it wasn't recognised anywhere.
さんによる
Confirmed. Re-did the adhesive cutting the whole for the mic. I got the opposite piece (4L) too because I wasn’t sure if that was also a mic hole. Sounds is great now.
さんによる
コメントを追加
The muffled microphone issue in the 2017 iMac 21.5" is caused by adhesive strips blocking the relocated mic at the bottom during reassembly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hello :) I found myself in this situation as well :) I had even tested the mic before taping everything up - but there I went and covered the mic with tape as well when putting everything back together :( . Just incase .... wished to share that I found an incredibly small ( no bigger than 2 cm) usb mic from amazon for 7$. When you turn up the "gain" in system preferences it sounds exactly ( 90%) like the original iMac mic if you wish not to re-open the iMac ... Thank you all again for sharing this find and story !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
A muffled microphone on an iMac 21.5" (Mid-2017) after replacing the adhesive strips usually happens when the display isn’t seated perfectly or something is blocking the mic path. Dust, misaligned cables, or pressure from the new adhesive can restrict sound pickup. Reseating the display carefully and ensuring the microphone area is clear often fixes the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Warren Wilson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 23
過去 30 日: 128
今までの合計 43,512
