メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
What did it break by charging MacBook Pro with a repaired MegaSafe?
History: my macbook pro did not charge but was working perfectly when connected to my old original megasafe. I bought a second megasafe power adapter (with the correct characteristics) from a company which repairs and resells them. After charging my mackbook for ten minutes with it, I realised that the laptop was extremely hot, like burning, I think the charger port looked also burned. I immediately disconnected the adaptor but the laptop did not turn on anymore. Also tried to charge it in the apple store does not work.
Question: what did it burn? How do I find out what is broken to be able to replace it!
Please help me!! It´s a pity to throw it away.
Thanks a lot in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Can you please confirm if by 'magsafe connector' you are referring to the internal magsafe board (also known as the I/O board, or DC-in), or are you referring to the external power supply?
さんによる
I´m referring to the external power supplier
さんによる
コメントを追加
1 件の回答
ベストアンサー
Sounds like you got a bad MagSafe charger.
There are quite a few clones out there which can damage your system! I'm suspecting the one you bought was one of these. Here's more on why you shouldn't buy these: Counterfeit Macbook charger teardown: convincing outside but dangerous inside and take a look at this: Lacking safety features, cheap MacBook chargers create big sparks
Here's a good Apple T/N on checking for a damaged unit and to check your computers MagSafe port: Apple Portables: Troubleshooting MagSafe adapters
Sadly, it sounds like your system was also damaged by the bad adapter. You'll need buy a REAL MagSafe adapter to see if your system was damaged. You might also need to replace the MagSafe port if it got damaged: MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement
If your system was damaged by the cloned adapter you'll need to sue the company that sold you the bad adapter to get damages to get your now damaged computer fixed. Now the hard part depending on where you live you might not be able to sue or the cost to sue will be more than getting your system fixed on your own.
Here's the IFIXIT guide to replace your logic board: MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement and the needed part:
MacBook Pro 15" Unibody (Mid 2010) 2.4 GHz Logic Boardの画像
製品
$159.99
MacBook Pro 15" Unibody (Mid 2010) 2.53 GHz Logic Boardの画像
製品
$189.99
MacBook Pro 15" Unibody Mid 2010 ロジックボードの画像
ガイド
MacBook Pro 15" Unibody Mid 2010 ロジックボードの交換
難易度:
難しい
30 minutes
MacBook Pro 15" Unibody Mid 2010 MagSafe DC-Inボードの画像
ガイド
MacBook Pro 15" Unibody Mid 2010 MagSafe DC-Inボードの交換
難易度:
中レベル
30 minutes - 2 hours
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Giada Carta さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 235
