メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mavic Proは、2016年11月に発売された折りたたみ式のコンパクトなドローンで、4Kビデオ撮影に対応しています。モデル番号はM1Pで、コントローラーのモデル番号はGL200Aです。
Left rear arm support replacement part?
I had a small crash that bent up a small plastic support piece for the left rear arm.
The drone still flies, but that rotor isn't flying parallel to the ground anymore (even with some duct tape support): https://goo.gl/photos/xxZGB68M9ZvfhDt16
top view and rear view (broken support is covered in duct tape)
I found Where to buy replacement parts, but I can't tell if this part is part of the middle frame, upper shell, or bottom shell since it doesn't look like it's connected to the top or bottom shell.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Alright, I figured it out. That piece is called the saddle, and it's connected to the arm.
I can't find anywhere to buy just the saddle, but by searching "dji mavic pro left rear arm" on ebay I found an entire arm with an intact saddle for $30 with shipping.
It looks like you can also buy them from Cloud City Drones, but they're out of stock at the time of writing.
Will update when it comes in!
2017-07-18 edit: it came in! Confirmed that that piece is part of the arm. Replacement was pretty straightforward - just a bunch of screws and minimal soldering. Some parts of prying the case apart were tricky, but nothing harder than an iPhone screen repair.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
2017-06-12 Update: those two side plastic parts that come with the middle frame aren't the same pieces. I'm still trying to track them down.
Figured it out as I was typing out the question.
These side plastic parts are part of the middle frame, which you can buy on ebay by searching "dji mavic pro middle frame". I found a middle frame with two side supports for $15.
I imagine it would be easy to 3D print this part - it's just a flat piece of plastic with a hole in the middle.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you so much! You just saved me hours of research. I just knocked my mavic pro out of the top of a 70' post oak with a dog ball thrower (that took awhile), and broke the left rear arm stop when I caught the drone. Going to look for a middle frame now!
さんによる
コメントを追加
回答を追加する
Christian Genco さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 4,423
