Wont idle when warm
Truck has a 22r. it runs fine until warm then it wont idle.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@lvec1 , Lou Vecchia, Possibly a stuck EGR valve or vacuum leak, although there are a lot of things that could cause idle problems, dirty carb., weak fuel pump, clogged filter, bad plugs, failing coil, etc. etc.. Links below may help trouble shoot your issue.
このアンサーは役に立ちましたか?
Ok Thanks. ill check the links.Going to work on it on Thursday.Ill post what i found. I have replaced the carb and checked for vacuum leaks.
my 2003 toyota truck will run but will not idle and dies
このアンサーは役に立ちましたか?
new gas tank and fuel pump and new idle senor. new fuel filter
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 2,121
