メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年7月にリリースされたXiaomiのRedmi Noteシリーズ初代モデル。Redmi Note TD-LTE 2014022は、5.5インチの大型ディスプレイを搭載した初のRedmiスマートフォンです。
Touchscreen does not accurately respond?
The touchscreen often does not respond to touch and will sometimes require multiple taps or swipes to perform a function.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
7 件のコメント
touch ways jumpering
さんによる 共有
Automatically touch display problem
さんによる 共有
Mine doesnt work at all, sometimes it work for a couple of hour or days and stop working for a couple of days even a week
さんによる 共有
my New mi max 3 touch does not work
さんによる 共有
i’m having the same problem with my redmi 7a, any progress with your device?
さんによる 共有
2件以上のコメントを表示
コメントを追加
5件の回答
最も参考になった回答
Hi! I had this exact same problem but I ruled out a hardware issue because every time there was slow to none response, if I turned the screen off and on again, it would fix it. I looked for a solution and after trying many, many things I discovered the problem was that I was using the Full Screen option offered by MI, i.e. the option to remove the three main buttons at the bottom of the screen (Back, Home and running apps) and to control the phone with gestures. After going back to the classic three button style, I restarted the phone just in case and I haven't had any more response issues in two days, I think it was a success!!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
hi are u still facing the problem?
さんによる 共有
I also face issues that sometimes many apps does not respond a after a while an error occurred that app is not responding sometimes I recieved that ui not responding
さんによる 共有
コメントを追加
If the touch screen is still responds to touch sometimes, it may be a software calibration problem rather than a hardware problem. To calibrate the touch screen, follow these steps from the troubleshooting page.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It started after i updated to miui 10 or thhe update before it.. now i am stuck and cannot downgrade my phone rom! It sometimes don't detect the touch, for a second or two.
さんによる 共有
コメントを追加
Your phone may be crashed, try to restart your phone or get a factory reset to have a try.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
still not working
さんによる 共有
コメントを追加
Before that, see the video below and know that Redmi Note 8 pro has both touch and heating issues. Check whether your phone also has these.
The problems on Redmi Note 8 Pro are touch issue and heating issue.
The first issue is the touch issue on Redmi Note 8 Pro, which I had noticed quite unexpectedly. Redmi Note 8 Pro display is sometimes unresponsive along the edges of the screen. I had thought that this touch problem would be a bug or defect on my device, but came to know that a lot of people have experienced this too. This might be due to the cheap quality touch digitalizer used by Xiaomi on this phone.
The second issue is the heating issue on Redmi Note 8 Pro. This phone was widely advertised by Xiaomi as a device with liquid cooling to prevent overheating of the phone. However, after playing PUBG mobile for a short while in an air-conditioned room, the phone started heating up. On testing, it showed a temperature up to 46 degree Celsius !
https://m.youtube.com/watch?v=0elP5IqZ-n...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Game playing screen touch and 360° rotation problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Slater Stewart さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 33
過去 30 日: 75
今までの合計 43,741
