Front Collision sensor not working
So my front left sensor on my 2014 1794 Edition Tundra is messed up. Every time I brake it goes crazy like I am about to run into something but I am not even close. Can anyone help?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@mayan ,Mayan, 2014 1794 Edition Tundra front left Collision sensor problem sensor may be loose, not positioned correctly, bad connection/wire, cracked allowing water intrusion or faulty sensor. You could try and have the truck scanned, may pin point issue. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. It may take a better scanner for reading this type of sensor issue as used at a dealer ship. If still under warranty have checked out by the dealer. Links below talk of this issue and may be of some help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 6
過去 30 日: 14
今までの合計 3,876
