Trouble opening ro replace battery
I am trying to open the bottom to replace the battery but it won't budge. Any suggestions?
You can try heating the end with a hair dryer, this may help loosen the battery cap. It is possible that the battery has leaked and that is making the flashlight hard to open. The heat trick should help with that. If the battery has leaked, try cleaning the interior with vinegar and some cotton swabs.
このアンサーは役に立ちましたか?
Maybe use some WD-40 and squirt in near it and let it soak down. Have you tried some pliers of grips to remove it?
このアンサーは役に立ちましたか?
Heat the top battery cap while insulating the bottom then put the bottom into crushed ice using a pot holderto hold thw hot cap then use 2 pair of pliers or grips to open
I tried with 2 pairs of vise grips and it won't budge I have no idea what to do.
過去 24時間: 1
過去 7 日: 16
過去 30 日: 113
今までの合計 17,878
2 件のコメント
I have this problem too.
Maggie Asberry さんによる 共有
Same problem! I have tried everything to get the end cap off two pairs of pliers, the hairdryer thing some I cannot get it to budge!!
Donna Jean さんによる 共有
