メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
boot loop after battery replacement
my iPhone 6 had battery problems like most iPhones these days battery percentage was all over the place jumping up and down for example from 40 to 5 % after suffering that for many months now I decided to have the battery replaced so I changed the battery at a repair shop yesterday not at apple cuz I don't have official apple stores where I'm at , now since morning my phone started suddenly restarting and stuck in boot loops for minutes then powering on , but as soon as I start using it , it goes in boot loop again and so on , when connected to a power source it's working fine , once disconnected the same happens, any idea of what the problem is ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
3件の回答
ベストアンサー
It's a bad battery. Take it back to where you got the battery replaced from.
These are common symptoms of a refurbished / repackaged / aftermarket non-original battery DOA (dead on arrival).
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
Ew. That shop needs to replace that battery out and do a proper volt test on it. Like Ben said before, it's a bad battery and might be part of a bad crop or by itself.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I don’t know if this will get added to this discussion, but I had a similar problem. I replaced a bad iphone 6s battery with one purchased through Amazon. It is a little tricky getting the old battery out and this is where my problem was. I unfortunately lost a couple tiny screws in the replacement process. The critical screw is the one holding the metal cover tight over the connection between the battery and iphone. I reinstalled without that and the connection was not tight (enough). The phone would start and be fine….for a couple minutes and then reboot. I opened the cover and scavenged another screw (needs to be the slightly longer one) and tightened that cover down well. No more problem with restarting.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
hero_2123 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 24
今までの合計 8,931
