メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 wifi seems very weak?
Using Iphone 6.
For a few days now my wifi seems to be working very poorly. I am only able to connect to my router when I'm next to it! It used to detect tens of different routers in my house but now its down to one or two..
Should I replace my wifi antenna?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Maybe. You also may want to do a force restart first. Maybe even a dfu restore. Instead if jumping in and replacing the antenna. You also may want to try toggling airplane mode, off and on
iPhone6のハードリセット方法
Plug your device into your computer with a USB cable.
Turn off the device.
Hold the Power button for 3 seconds.
Hold the Home and Power buttons for 10 seconds.
Release the Power button but keep holding the Home button.
More items...
Hmm, kinda surprised they don't have a guide for this. Remove the logic board using this guide, then remove the antennae on the back
iPhone 6のロジックボードの交換
iPhone 6 Logic Board Antenna Flex Cable
iPhone 6 Logic Board Antenna Flex Cableの画像
製品
$9.99
iPhone 6 ロジックボードの画像
ガイド
iPhone 6のロジックボードの交換
難易度:
中レベル
30 minutes - 2 hours
iPhone 6の画像
ガイド
iPhone6のハードリセット方法
難易度:
とても簡単
25 - 30 seconds
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thank you very much for your quick reply! Force restarting didn't seem to work, will try to factory reset tomorrow and if that doesnt work I will replace the antenna. I actually found a link with an antenna for 0.82 dollars!
さんによる
Ha. I've found that cheap parts usually give me more problems than when I started
さんによる
Ooh that's good to know! I will find a better site then;) thank you!
さんによる
コメントを追加
Teun if you have dropped your phone recently it will probably end up being the antenna and I agree with @theimedic on staying away from cheap parts. Just some advice if you have never pulled the logic board out follow the guides exactly and keep track of the different screws. Also the antenna is very thin and flimsy so be very easy when removing the old one, I have unfortunately ripped the connector off the board side before, not good! I just replaced one with weak wifi actually the same as you are describing and once I was done it made a huge difference. Good Luck!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Oh, yeah. @avmech00. I totally forgot. I recommend, if you're not doing this all the time, a plain white piece of paper will do. Organize the screws exactly as you took them out, and return them in same. It could be detrimental to your board!
さんによる
Thanks so much for your replied guys, I love the iFixit mentality and community!!
さんによる
コメントを追加
reset your sim card,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Teun Bruijnen さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 21
今までの合計 39,577
