メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1990年から1993年モデルの第4世代 Honda Accord。クーペ、セダン、ステーションワゴンの各シャシーで展開。
Why is she clicking?
When I start my 91 accord dx something under my hood clicks. I have transmission issues already, I have 3 out 5 gears and one of them grinds when shifted in to. I am new to the whole car problem thing and I am hearing different things from different people. I am making sure that that click is my tranny not my engine correct.?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
@shaybaby can you describe where under the hood the clicking comes from? It would be unusual for a transmission to click while it is in park....
Rep: 1
さんによる
It sounds like it is coming from the transmission but it is hard to tell cuz the engine is slightly over it also so it difficult to explain in the middle but over to the left about 6 inches.
さんによる
Does your car have a turbocharger or supercharger?
さんによる
No it does not. Basic 91 Honda accord
さんによる
Hi @shaybaby
Just to clarify. Does it click when the car is stationary or when it it being driven or both?
Does the clicking speed up or slow down as you increase or decrease the revs of the motor?
If it occurs when stationary, select neutral or park and rev the engine slowly up and down to determine if it changes. Ensure that the emergency brake (parking brake, handbrake whatever you know it as) is applied when you do this.
Is it there all the time or does it come and go?
さんによる
コメントを追加
2件の回答
最も参考になった回答
@shaybaby ,babygirl143love , Use the links below to help determine what the noise is in/on your vehicle( 1st link, you click on the items and noise will be played back for various issues). Really if your car has already lost transmission gear usage and grinds, you should seriously consider stop driving/using the car before catastrophic failure, causing a serious accident or leaving you stranded. If not comfortable working on your vehicle have a good shop take a look, diagnose and estimate repair. Good luck.
http://mycarmakesnoise.com/
http://www.onallcylinders.com/2014/01/24...
http://www.bankrate.com/finance/money-gu...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Is it making that sound while its idling or while you're actually moving because of transmission shouldn't make any noise at all if you're not in gear
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
After turning it on and letting it run it clicks but it only click quietly sometimes while riding in 4th
さんによる
@shaybaby I can source this problem a lot easier for you if you send me a recording/video of the noises. Cunnington51@gmail.com
さんによる
Please do the recording both inside the car and with the hood open at the engine.
さんによる
@shaybaby
@mayer made a good point. But I also need to hear it run in neutral, and while it's in gear. Then I will most definitely be able to pinpoint the problem. Dealt with a lot of Honda cars over the years.
さんによる
コメントを追加
回答を追加する
babygirl143love さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,311
