Internal hard drive disk not recognized
Hi there,
My internal hard drive disk has stopped working on my Macbook.
The hard drive is not recognized at boot up, so I get the famous question mark. I tried to connect another hard disk and got the same error message. So I guess the problem comes from the logic board?
When I try to access it from the external bootable drive using Disk Utility I can't see it either.
The disk I'm using is good, and it works when connected with USB (this is what I'm running now). But of course I would prefer to put it inside and connect it with SATA.
Now, I'm wondering what I should do. A new logical board is expensive, and it would be too bad to change it completely, because everything else is working perfectly. So, I'd like to get some advice, maybe for how to check the connectors, change the disk controller or add a new one, or whatever can help to get a more practical solution.
Thank you for your help.
この質問は役に立ちましたか?
15 件のコメント
Obviously, if it works with USB , your LOGIC Board is OK
Bernard Levesque さんによる 共有
probably the flex cable
Mark mercer さんによる 共有
more than likely its a flex cable that connects your drive to your board
I have the same exact issue on. A 2014 macbook pro, changed the flex cable still the same results
Eric Armstrong さんによる 共有
My sons macbook suddenly didn't want to boot from a ssd-disk that had worked perfectly for almost a year. The disk is however readable when connected with usb. I tried with an older rotating hard drive, connected it using the flex cable, and it did boot and worked as it should.
Are Voll さんによる 共有
10件以上のコメントを表示
