メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Home button issues after screen replacement
Hi, I removed a broken screen, I removed the HOME button as described in the repair guide. The issue I have now is the home button cable connector. Where do I connect this on an ifixit screen? There does not seem to be a connector for it on the new screen.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Did you transfer the back Metal plate that has the home button extension cable on it?
Some replacement screens do not come with the metal plate with home button extension cable depending on if you bought the 'full assembly' or just the screen.
Edit: This was the solution.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
That worked. Thank you so much.
さんによる
コメントを追加
Ben answered your question I do believe....you might want to give him the credit he deserves. It gets overlooked often and I'm sure you didn't mean to, but the board would work better if everyone would give good questions a Yes vote, and label helpful and correct answers as such.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I usually post comments for quick questions next time I'll post it as answer.
さんによる
@benjamen50 I often change Ben's comments to answers (about once a day). As to voting,, almost no one does. @oldturkey03 and I probably cast more than half of all the votes.
さんによる
@theboardrider thank you for pointing this out. Let's take care of each other....
さんによる
Thanks all! I never even thought that I need to make sure I "answer," instead of "comment!" But that makes sense...
One evening I was going through and answering unanswered questions...and giving all the good one's a vote for being a "good question," trying to be a good board contributor ;).
I then noticed as people were replying to my comments, nobody was giving me or my answers any credit! Even when I'd just given their question credit, and it seems that my answer had helped. I was pretty frustrated by this, not mad, but frustrated. People should slow down and try to give each other credit where deserved.
さんによる
コメントを追加
回答を追加する
Jesse Seguin さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 3
今までの合計 84
