My USB port stopped working
My USB port has stopped working is there any way that I can fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You may need to replace the USB port. This is fairly easy to do. It is soldered onto the circuit board with 6 contact pins. If you do not know how to solder iFixit has a great guide here. はんだ付けとはんだ除去の作業ガイド
Make sure the soldering iron reaches temperatures higher than 300 degrees Fahrenheit. Hope everything works well for you.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 324
