Why does my monitor make bad sound?
When I try to play audio from my monitor, the speaker produces distorted and low volume sound. What can I do to fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your problem is likely due to some kind of damage to the speaker, which makes the sound muffled or distorted. You will need to replace the speaker.
If the speaker is replaced and you are sure that you have installed it correctly, but the sound is still low while volume is set to the maximum, your battery could be weak. Check out the monitor's Troubleshooting Page for further help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 27
今までの合計 727
