メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
Do the replacement screen have one or two connecting ribbons?
iMac 27" EMC 2546 A1419 (Late 2012)
Hello, Do these replacement screen
> 27-inch LCD LM270WQ1-SDF1 PN: 661-7169 <
come with one or two connecting ribbons?
Seem that there should be two to disconnect when on takes the screen apart but when I go to order a replacement screen, seem that they come with only one ribbon.
Shouldn't there be one for the LCD and one for the Digitizer?
For this iMac
iMac Intel 27" EMC 2546
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
OK. FYI: When you buy the Screen assembly, it only comes with one connector cable, the one shown in this correct model screen assembly on the picture Jamie uploaded. The Ribbon cable to the new Screen Display port lcd cable, 98% of the time does not come with the new Screen you order and must be purchased separately only IF, your existing one is damaged. Ask the seller if they send it with the replacement screen so you are aware if to order one!
One more detail! You will need new mounting adhesive tape to reassemble your new Screen! You must buy a new set or ask the seller if they send an adhesive kit with the screen they are selling you!
This will save you time after your get the screen, so you don't have to wait again for just the Adhesive to arrive, to complete your installation!
If the existing Display port lcd cable on your existing screen is OK, you can just swap the old screen Display port lcd cable to the new Screen Assembly!
See This interchangeable ribbon Display port lcd cable here below!
The 2nd connector, the Display Ribbon!
Hope this saves reader's time/delays, money and troubles!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
OK, thanks, that is what I have been seeing.
I suppose one has to take the Display Port Cable from the old Screen and swap it to the new one!
I was afraid in ordering because there are two ribbons to be disconnected but I guess this port ribbon is disconnected at both ends and is swap-able!
Thank you Jamie, that was a quick response!
Cheers
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Quick but incorrect!
さんによる
コメントを追加
この回答は他の質問に帰属しています。
There is just one ribbon as you can see in this full assembly unit below
Good luck with your repair!
このアンサーは役に立ちましたか?
スコア -1
3 件のコメント:
It is alway good to post links to your references. We have no way of knowing where that one came from, or if it is even the correct display.
さんによる
Look carefully!
The image of the display unit you have in your answer has two connections. The black cable on the left is the backlight power lines not a ribbon cable. The ribbon cable is missing in this image, it connects to the top midpoint connector.
さんによる
Thansk Dan for the Clarification!
i got it!
The Ribbon cable is the one that comes off both ends from the old screen and placed in the new screen!
Do I have this right now? About the reuse of the Ribbon cable one!
さんによる
コメントを追加
回答を追加する
Carlos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 381
