No power after battery replacement
I recently dropped my phone in a pool. My phone would go in to recovery mode but only if connected to power. The display was working (showing the itunes icon).
I replaced the battery but nothing showed up on the screen. My computer will recognize the phone but there is no response from the phone. I did not disconnect the screen when replacing the battery and I made sure not to damage the ribbon cables.
I also tested the old battery with the same result. The only thing I can think of is that I dropped the screws to the metal lcd panel so I cannot connect it but a new screw set is coming so I will be able to connect it later.
Why is my phone not turning on?
Is the metal lcd panel required to turn it on?
この質問は役に立ちましたか?
