メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Toyota Pickupの第4世代です。
were is fuel pump at
were is fuel pump located
Update (06/27/2016)
were is fuel pump on 1986 toyt pick-up
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@toodles1234 okay lets try this. It does sound like you are looking for the fuel pump location on a 1986 Toyota Pickup. You need to tell us what engine your Toyota has. Remember that all '75-'87 20R-22R engines have carburetors. The '84-'87 22R-E engines have fuel injection and models with 22R-TE engines have fuel injector plus a turbocharger. on a '80-'87 20R and 22R engines the fuel pump is bolted to the right front corner of the cylinder head. Three hoses are connected to it. ON 22R-E and 22R-TE engines, the fuel pump is mounted inside the gas tank.
画像
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
The fuel pump is located in the fuel tank, and the tank must be lowered to access it. The fuel filter is located on the engine block, passenger side, underneath the intake manifold, above and to the front of the starter.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Not if it's a 22re. Then it's inside the fuel tank.
さんによる
コメントを追加
回答を追加する
dennis bakke さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 53
今までの合計 14,905
