How To Repair My Television
Plz suggest me how to repair my Tv.
Last 2 dy my Tv screen cut image .
Tv up side like negative screen & down side Normal so plzz
what's problem...
Update (06/12/2016)
See up side crop picture
この質問は役に立ちましたか?
what's problem...
この質問は役に立ちましたか?
@mayur unlikely that this would be caused by a bad LCD or a bad driver logic. I would suggest that you start with your settings first. Make sure that you have things like "mirrored" etc. not accidentally turned on. If your menu has a factory reset, try that.
If you are 100% sure that your settings are right and that a reset did not resolve this, you'll have to open up your TV and take a look at the boards. Check for obvious damage and post images of those boards with your question.
このアンサーは役に立ちましたか?
What's Problem My Tv.
Plz Tell Me Details...
I hve open My Television And Clean Dust Also.
Bt No Idea What Can I.
So Plzz Explain Me..
This Problem Faced Last Two Weeks .
Power Shut From Electricity .When
Power Come That Time To Till Date This Problem Faced..
I Don't Understand What's Problem on Television..
@mayur Have you done a complete reset yet? Go into your TV's setup menu
Which side show reset menu
過去 24時間: 12
過去 7 日: 15
過去 30 日: 29
今までの合計 436
2 件のコメント
post your question in normal english and a little bit more details. And a good picture would help to...
Rudy さんによる
mayur さんによる
