How to change cpu and gpu?
how to change my lenovo g 50 cpu and gpu?
If these are diagnosed faulty, they can be replaced with exactly same models using specialised soldering equipment, however they are most likely non-upgradeable due to high firmware and BIOS integration.
このアンサーは役に立ちましたか?
I suggest attempting to reset the cmos on the motherboard via a jumper labeled pwr cmos, power jumper or just plainly, a big shiny flat yet round coin style battery. There are lots of tutorials on that topic with more info than I care to share here. Good luck!
このアンサーは役に立ちましたか?
And how is this related to the question?
If you are limited by firmware settings and bios settings you can reset the cmos in order to bypass them. Then you could try a different chip. Sorry, I’m tired.
In other words, reset the cmos by taking the button cell battery out.
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 2,060
