Short Circuit Navigation Electronic Problem
I had a problem with my car. There was no current in the battery and I put a new battery. But after one day I had the same problem, no current in the battery.
After I tried to check with the fuses which circuit the problem is. After long search I found out that the RNS-D an particulary the navigation is consuming the battery.
Is it a common problem with this RNS-D system?
Is it possible to fix it? And how much will it cost?
Kind regards
Hi, Doesn't it switch off when you turn the car ignition off?
jayeff さんによる
