メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ジャンプ・ドライブ、USBスティック、サムドライブとしても知られるUSBフラッシュドライブの修理ガイドとサポート。
How do I fix a DEAD flash Drive?
I have a Crucial 32 Folding flash drive. Worked fine on Tuesday night, plugged it in on Wednesday morning and... Nothing. Absolutely nothing! Problem is, it contains ALL my files (of course) which I need (of course). Is there a way to fix it myself (I have a "little bit" of electronics skills) , or should I send it off and jus pay the $$$$ to have it fixed and data recovered? Any ideas, suggestions? HELP?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
4 件のコメント
Did you rule out the computer usb ports? If so, you can start with an electronics cleaner and brush in the flashdrive plug.
さんによる
Yes. Tried it in two diff computers. It "thinks" when I plug it in , then nothing. Opened it, no fuses or bad connectors . now what??? Is there a way to directly access the chip? Or can I take the chip out & put it into one that works?
さんによる
i have a dead usb and a I want to repair it. but no , i trying diskpart,mini partition and disk genius but no. but he doesn't want to create a partition for me pls a app he is reparing a usb
さんによる
hi there is t there a way to get access to a dead USB
さんによる
コメントを追加
4件の回答
最も参考になった回答
Before you take it apart try downloading easeus data recovery see if you can see your data there
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
Good thought.
さんによる
@pccheese explain your vote on this answer to me.
さんによる
@oldturkey03 I have found no solution in the answer. It would be wiser to "remove as not an answer" than spam, though. My reason for a spam vote is because the recommendation of the software without any actual problem solving.
さんによる
@pccheese actually I think it is very wise to check recovery programs before a physical repair. I'd think spam if there would have been an actual link to it, but there was not. Looks like personal preference to me;-)
さんによる
コメントを追加
A BGA rework professional may be able to swap the memory to a new flashdrive, but without a hot air station you don't have a hope of switching it. Try pressing on the chips while you plug it in. Maybe it will work long enough to get your data. If not I would have to say send it in and pay. :(
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
use partitionGuru Software
and change the drive letter maybe from E to R
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If your Crucial 32GB Folding Flash Drive suddenly isn’t detected, first try basic checks: use different USB ports, another computer, and avoid USB hubs. Check Disk Management (Windows) to see if it appears unassigned. If detected, don’t format—use recovery tools like Recuva or TestDisk.
If it’s completely dead (no detection), it’s likely controller failure—DIY repair is risky and can worsen data loss. In that case, professional recovery is safest. Avoid repeated plugging attempts, as it may damage the memory further.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
deadflash さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 40
今までの合計 18,234
