How can I replace my LCD Screen?
My screen recently broke, it refuses to turn on. I read through the tear down and was unable to determine what I should do in order to replace the screen.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Mitch,
Try taking a look at the LCD replacement guides for similar models. The HP EliteBook 8440p has a LCD replacement guide and so does the HP EliteBook 6030p. You can also find a replacement part on Amazon. The replacement LCD for your laptop can be found here. Be sure to double check your model numbers to be sure you've ordered the correct part. Good luck!
ガイド
難易度:
中レベル
45 minutes
ガイド
難易度:
簡単
20 - 30 minutes
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 3,040
