メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年に発売された5段階変速のハンドミキサー。ビーターが付属しており、ホイッパーやドゥーフックなどの複数のアタッチメントにも対応しています。
Beaters keep falling out!
Every time I try to mixes anything harder than average beaters fall out of the mixer after a few seconds of working. Is there anything I can do to make them stay in the mixer (no I don't press the eject button accidentally).
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
I have bought 2 of them and the same thing happened both times. The beaters made a funny sound like they were hitting each other. Then quit working. One I used for awhile and the 2nd one I only used about 1 time. Will never buy this again.
さんによる
My beaters keep falling off too. Disappointed in Staten Island, NY.
さんによる
I've only used mine 1 other time and it's already doing this for me as well. I went to use for a second time after just buying it and one beater kept coming out. Will never get this brand again!
さんによる
コメントを追加
2件の回答
ベストアンサー
When you plug your beaters make sure you can hear a “click” noise that assures they are plugged in all the way. If there is no noise when you stick the beaters all the way, the tabs could be broken. Examine the beaters for damage to the tabs, replace the beaters if necessary. If everything is good with the beaters, the mixer’s spring that holds the beaters could be damaged and it will need to be replaced.
Check out the section on beaters falling out on the KitchenAid KHM512ER Troubleshooting Page .
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
When I went to used the mixer today, only one of the beaters would lock in place. It appeared that the small metal tabs on one side were a bit lower than the other. To fix it I used a very small flathead screwdriver and gently pried upwards on each of the metal tabs. After doing that the tabs engaged with the tabs on the beater and it worked properly. I'm sure there are other failure modes, but this worked for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Yuriy Zaynulin さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 20
過去 30 日: 114
今までの合計 23,393
