メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung SyncMaster 245Bは、TFT(薄膜トランジスタ)アクティブマトリクス方式を採用した24インチのLCD(液晶ディスプレイ)モニターです。
Is my panel dead?
Hi ! I'm new to this site, so please forgive any mistake I might make in regards to my description and please forgive my poor English as well.
Here's my issue: my screen (a Samsung SyncMaster 245B) stopped working recently, the blue LED indicating power still lights up, but the panel itself stays black (it usually shows a grey box when nothing is connected to the screen at the very least). So I'm wondering if the panel itself is dead or if it might be another problem.
And I'm also wondering in case of the actual death of the panel, is it worth replacing or should I straight up buy another screen instead?
Thanks for your time and your answers to come ! :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Have you tried the repair solution described ?
Maby it´s just that, a dead resistor in the power supply ?
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
Hey, Sinouhe. Apologies that this comes months after you asked the question. I own two Samsung SyncMaster monitors, both of which had the same behavior you're describing. In both cases, the root cause was a couple of blown capacitors on the power supply board in the monitor. If you have the skills and tools to repair it, you're looking at a $5 repair.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Sinouhe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 31
今までの合計 1,925
